Rear spring installation question
Old Nov 7, 2009 | 01:03 PM
wcsinx's Avatar
wcsinx
Default Rear spring installation question
I bought the 7 leaf F41 rear spring from Duntov.
I got the 3.25" grade 8 bolts from Zip which is what they list for the 7 leaf.
Now measuring the thickness of the spring at the middle, I get 2.5". The bolt holes are around 0.75" deep. So for full thread engagement, that puts me right at 3.25". But once you add in the thickness of the mounting plate & lock washers, and the fact that the spring is slightly arched at the middle because it's fully relaxed, I can't even get these bolts to start threading in.
Am I missing something here? Should I have used the 3.5" bolts for the 7 leaf? Are there significant variations on the thickness of the spring depending on manufacturer?
At the rear holes, I guess it doesn't matter because they're open at the top so I can use as long as bolt as I want. The front holes however, I run the risk of punching through the cover if I use the wrong bolts. And in fact that's why I have a new cover now because the last owner torqued right through the old one.
Old Nov 7, 2009 | 03:48 PM
69small block's Avatar
69small block
Default spring
i used a small floor jack with a 2by4 on its side to put some tension on the spring about 15 in. long this helped to flaten it out somw to help gget things started
At the rear holes, I guess it doesn't matter because they're open at the top so I can use as long as bolt as I want. The front holes however, I run the risk of punching through the cover if I use the wrong bolts. And in fact that's why I have a new cover now because the last owner torqued right through the cover.
Old Nov 7, 2009 | 08:05 PM
wcsinx's Avatar
wcsinx
So you had the same situation then before flattening it out? I.e. virtually impossible to get any thread engagement between the width of the spring, plate, and lock washer? Are you using the 7 leaf as well and what length bolts?
Old Nov 7, 2009 | 09:09 PM
noonie's Avatar
noonie
I usually put the 2 rears in snug, so the spring won't go anywhere, and then let the car down to flatten it as much as possible. Then I use a set of V calipers in the hole to measure.
Sorry, didn't record the lengths.
Old Nov 7, 2009 | 09:20 PM
hdpete98's Avatar
hdpete98
Also, do NOT tighten the bolts until you have the car on the ground and the spring under full load. If you tighten the bolts fully without the spring under load, the differential housing can crack when you set the car down.
Pete
www.c3vettes.net
Old Nov 10, 2009 | 09:52 PM
wcsinx's Avatar
wcsinx
I'm just going to type this up for my own sanity. I grabbed my calipers and crawled under there again tonight.
spring thickness at the center as 2.50"
Mounting plate is 0.25"
Lock washer is 0.15"
So that added up is right at 2.90"
The 7 leaf bolts I have are 3.25"
So that leaves you with 0.35" worth of thread engagement, which ain't much but I guess it's good enough.
I measured the forward bolt hole at 0.77" deep bottoming out the bolt by hand which means a 3.25" bolt leaves 0.42" of unused thread. So me being that **** rententive engineer I am, I grabbed some 3.50" bolts to use up another 0.25" of thread leaving just 0.17" of unused thread in the hole.
I'm not sure it matters, but I'll sure feel better knowing that spring is held on by more than ~1/3" of thread!
So FYI if you get a 7 leaf spring, theoretically the 9 leaf bolts won't damage your cover.
Old Nov 10, 2009 | 10:40 PM
noonie's Avatar
noonie
3/8" certainly isn't much.
I ended up assemblying my own spring using a Guldstrand shortened lower leaf (twice as thick) and using the original bolts. I needed extra thickness, so I made a 1/4" plate the same dimensions as the oem clamping plate. Seem to remeber I had close to 1" threaded. Worked out well since the original ears were bending when tightened anyway, now they don't.
Old Nov 10, 2009 | 11:31 PM
wcsinx's Avatar
wcsinx
That's a nice looking setup.
But I sure hope you didn't thread 1" in on the forward holes because you poked through the cover if so!
fiberblast's Avatar
fiberblast
try compressing the spring without the washer, lock washer etc, get them started then after you tighten them up and compress the spring, remove one at atime and add the washer etc...it worked for me.
Old Nov 10, 2009 | 11:34 PM
wcsinx's Avatar
wcsinx
Yeah, that's what the guys at Duntov suggested as well. While I'm sure I can get the 3.25" bolts threaded like that, I'm going to go with the 3.5" bolts. I figure I might as well use all the thread I can!
Old Nov 10, 2009 | 11:57 PM
noonie's Avatar
noonie
No worries there, I've had the bolts in and out a few times. I do remember cleaning out the threads with a bottom tap, so that may have gained a bit, especially if they used a starter or mid tap originally.
Probably good idea to record all the measurements for future reference.
To Rear spring installation question
