Im just curious, im 6"4, have a size 11 and i cannot brake with my right foot, everytime i try my foot gets stuck under the brake pedal (my brake pedal is really high compared to the accelerator, dont know if its normal!), or i hit my knee in the steering wheel!
The only solution i find is to break left footed! Luckily its something i always did, just for fun even on manuals, but in my vette i dont have a choice.
I am curious, I am 6 foot 2 and built long legged, I too wear 11 and never had that problem...I owned many c3's and even a mid year.
Drove several C3's daily...
Could it be that my break pedal is to high? Is it ment to be more or less at the same level as the accelerator?
Am i the only one forced to do that?
Nothing wrong with using your left foot on the brake in an automatic, in fact that is the way i have always done it. I used to work in the dealerships and had to squeeze new cars into the showrooms and tight storage areas with only inches to spare and got into the habit. You have much better control in critical situations and doesn't hurt anything as long as you don't ride the brake and the gas at the same time. Just don't try this with a standard shift.
Same here the tight quarters in a dealership makes you a left foot "brake'r" and its a hard habit to break.
have always braked with my left foot--don't know any other way--camber
DITTO, with the obvious exception of stick shifts....
now as I have aged (65) I have found my personal ergonomics have changed...primarily due to arthritis....and so my '72 vert has some 'minor' adjustments done over the years...
first up was a smaller steering wheel and TTele column....a few years later I lowered the seat in the rear by removing the mounting flanges....it hits the rubber block on the rear deck a bit...but I adjusted the seat position bolts upward to stop most of that....dropped the padding and carpet out from the front bolts too....
then to get my legs off the wheel, I cut the floorboard from side to side and up to the steering column height...bent it forward 3" and glassed it in.....then heated the gas pedal rod, lowered it some 3", and then did the same for the brake....which is a Hydroboost unit BTW....so no longer feels like mush when braking...
You would be surpised how many people think left foot braking is illegal,
The only thing to avoid would be using the brake pedal as a foot rest as much of any pressure could drag the pads enough to heat things up and perhaps even boil the fluid or have brake fade.
braked this way for over 50 years--my left foot is actually on the floor a little on it's edge with the inside of my foot--big toe area-- touching very lightly against the edge of the brake pedal--not resting on top--I find my reaction time is quicker then taking my right foot off the gas and applying the brake--I always know where the brake pedal is at all times ----anyways hard to explain but has always worked for me--Camber
Yep, since my first automatic. Its the natural thing to do.
Also, it has kept me from many accidents since you have better reaction time, I'd say half the time of right footing it.
I think it was my oldest child and on her driving test the officer told her that she couldn't use her left foot on the brake. I asked her if she asked him where it said that in the Texas law. She said no, daddy.
Yeah me too. Add my size 12s to the list of left footed dealership brakers. Back in the pre-fuel injection days you needed to be able to do this to keep a rough running carberated car from stalling.
Hi carlos840,
Try changing the type of shoe that your wearing. A lot of shoes have a wide sole making it hard to drive these cars.
I looked around and found a couple of shoes that I bought and now have more room down there.
Of course if you want you can look into the race driving shoes. There even narrower then the ones I bought at bass pro shop.
I'm 6'2" with a size 12.
Thanks everyone....
Im still wondering if my brake pedal is not to high? I physically cannot fit my leg on it without hitting my knee in the steering wheel!
Its probably 3 inches higher than the accelerator! Is that normal?
Regarding the shoe wideness, im ok, its really the leg length or pedal hight that is a problem.
