Spare Key
Old Nov 21, 2009 | 06:21 PM
Baldwin Brave #77's Avatar
Baldwin Brave #77
Default Spare Key
I accidently locked my keys in my 1978 Corvette and I don't have a spare. Is there any way I can a spare from Chevrolet or is there any other way to get in the car.
Old Nov 21, 2009 | 07:21 PM
Duke94's Avatar
Duke94
Do you have the key numbers? If so, any locksmith can make a key based on the code.
Gary
Old Nov 21, 2009 | 07:29 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
Willcox has some of the original style blanks. Makes nice extra sets.
Old Nov 21, 2009 | 07:37 PM
nutsy's Avatar
nutsy
YES, JUST GET A FIST SIZED ROCK AND THROW IT THROUGH THE WINDOW. i did this on a nova once when we were ice skating and freezing our -ss off. any locksmith should be able to get in.
Old Nov 21, 2009 | 07:43 PM
tnovot's Avatar
tnovot
Your local GM dealer probably has what is called a slim jim. It's a flat flexible metal strap with a hook shaped cutout on the end for sliding down the the inside of the door outside of the glass and catching the rod which is connected to the lock mechanism. The local dealer here does house calls so maybe yours does too.
Terry
Old Nov 21, 2009 | 08:31 PM
...Roger...'s Avatar
...Roger...
I used to have a video to show how to get into the car through the door handle using an oil dipstick but for some reason I can't find it.
Old Nov 21, 2009 | 09:15 PM
wro87's Avatar
wro87
I have had the dealer run the vin # and was able to get keys cut from that. My local guy has done it several times on our trucks and I would think that they can do it for yours also .
Good Luck wro87
Old Nov 21, 2009 | 11:17 PM
71coupe454's Avatar
71coupe454
Heres what a slim jim is http://truhcapital.com/images/ez-jim.jpg
you can make one real quick out of about anything laying around thats simular. Takes about 3 seconds to get into about any old car, dont know about vettes though..
Old Nov 22, 2009 | 12:14 AM
Aggitated Monkey's Avatar
Aggitated Monkey
A Vette is difficult with a slim jim because of the covers in side the doors around the door lock mech.
I sent Baldwin Brave #77 a PM that may help.
Old Nov 22, 2009 | 12:36 AM
1975greenconvertible's Avatar
I recall reading something on here about being able to pop the T-top off by going in between the window and T-top weatherstrip with some kind of rigged up tool.
Old Nov 22, 2009 | 01:35 AM
71coupe454's Avatar
71coupe454
I read in here to smack the t-top with your hand to make the latches fall down
Old Nov 22, 2009 | 08:56 AM
...Roger...
I wouldn't try that on the 78 laminated blue glass tops. If they're fiberglass tops give it a try.
To Spare Key
