Lighter/courtesy light/clock circuit question
Old Nov 22, 2009 | 11:47 PM
mensch53's Avatar
mensch53
Default Lighter/courtesy light/clock circuit question
I know this is the subject of many electrical frustrations, but I may have a slightly different problem...
I have a 72 and none of the items on this circuit works. I figured the fuse must be out or there is a short that would blow the fuse. So, today, I checked it out and found that the fuse was intact. I figured I might as well make sure, so I replaced it anyway. Nothing happened. It did not short out nor did it fix the courtesy light, lighter, or clock.
Any ideas? Is this a problem with the fuse block?
Thanks!
Old Nov 23, 2009 | 08:27 AM
...Roger...'s Avatar
...Roger...
First get your test light out and make sure both sides of the fuse is hot and both contacts that the fuse fits in is hot.
Old Nov 23, 2009 | 03:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Lighter -- check power lead; check console trim plate ground
Clock -- could be dirty; original movement might be burned out. I ran a separate ground to my original clock and it runs like a charm.
Courtesy Lights -- check door jamb switches.
To Lighter/courtesy light/clock circuit question
