What is the average number of shims needed to get the right camber on a '73? Or is this a stupid question? And why would there be a ton of shims on it now and still need more? What is the maximum number of shims and still be safe?
Hi Terry,
I'm thinking the same as Mike. To me, a lot of shims would indicate a frame that's been hit, a bent A-arm, or perhaps a front end that's not assembled correctly.
Regards,
Alan
It's got maybe 5 or 6 on all 4 bolts, I rebuilt the front end and it had a bent crossshaft and I replaced it. One of the bolts is not long enough to add another thick shim ! Is there anyway to adjust the Lower Control Arm ?
look for signs of repair on the inner fenders. This is a sure sign the the frame is tweeked most likely from a prior accident
Originally Posted by Alan 71
Hi Terry,
Regards,
Alan
On my 76, the crossmember under the engine was hit. It rolled towards the back of the car, requiring a "ton" of shims on the front bolt and none on the back bolt. I had to have a frame specialist pull the crossmember forward to get it aligned. The lower control arms mount on the crossmember, so they moved with it.
You might want to install a spreader bar like the one VBP sells. You would be suprised how much the front crossmember flexes. Put a jack under the front crossmember and lift the front wheels off the ground. Then install the spreader bar and lower the car and I will bet you could take half of the shims out to maintain the correct camber. When the crossmember flexes from age or whatever, the more shims you need. You can also purchase offset upper a-arm brackets and install the offset pointing out to lower the count of shims for correct camber.
Scratch my last advice on shims. I was thinking backwards. If the crossmember is weak, you would have to remove shims to correct camber. Sorry for the mixup.
My 77' has 2&2 on each contrl arm. they vary in thickness, have a shop check the front rail's they could be bent or not plumb [what I mean is they could have flexed due to a hit or a bad allignment that just got worse]
