Help decoding 71 rear end numbers
Old Nov 30, 2009 | 06:00 PM
dmayhew's Avatar
dmayhew
Default Help decoding 71 rear end numbers
Can anyone assit with decoding the following rear end code?
1 AB 8870 W
I have read in the restoration guide and have looked at a sample code for a 71 car
The 1 in front is not something I have read that should be there.
On a 70 car it indicates the shift that built the unit, but not sure that info was there for 71
On a 71 the AB is 3:70 and 70 cars used 3 letters
So it should be a 71 unit.
The 8 8 7 0 , I think this may may be 8 for August / 8 for the day of month or August 8th
and then 70 for year and W for assembly plant or possibly maker of the gear set.
Thanks David
Old Nov 30, 2009 | 06:43 PM
early shark's Avatar
early shark
Your stamping is a little off from what I see mostly, however you might have a early built '71 (low VIN). Here is what I usually see on '71's, both are from my cars.
1 AB W 067 E 1 or 1 AW W 061 E 1
The W is for the gear & axel plant in Warren, MI. The 1 at the end is for the day shift vs 2 which is for night shift. The 067 or 061 is a Julian date, it stands for the sixty-seventh or sixty-first day of calendar year 1971.
Old Nov 30, 2009 | 07:57 PM
dmayhew's Avatar
dmayhew
Thanks Early Shark
Is the 1st # 1 the year model indicator?
Not sure why the rest of the numbers are not in line with the norm.
David
Old Nov 30, 2009 | 08:36 PM
Mike Ward's Avatar
Mike Ward
AB= 3.70 ratio.
Old Dec 1, 2009 | 02:51 PM
dmayhew's Avatar
dmayhew
Thanks Mike
I ha teh 3:70 part , its teh other numbers that are not in line with the normal 71 pattern of numbers
DAvid
To Help decoding 71 rear end numbers
