1 Horn, 2 Horns?
Old Dec 4, 2009 | 11:16 PM
Vette Rookie's Avatar
Vette Rookie
Default 1 Horn, 2 Horns?
My 73 only has a single horn, not a low and high. There is also no extra lead for the second horn that I could find. When did GM start using 2 horns? Or was it just an option to add the second horn?
Old Dec 5, 2009 | 12:56 AM
not a '76's Avatar
not a '76
IDK if this is how they came from the factory, but my vette has a horn or two up front and one hiding behind the driver's side rear tire.
Old Dec 5, 2009 | 01:08 AM
63vert's Avatar
63vert
2nd horn was an option, you should be able pick up the horn and the horn extention harness from wilcox, don't know if they carry the bracket. The horn behind the rear wheel is part of the security system GM installed.
Old Dec 5, 2009 | 01:10 AM
MakoShark72's Avatar
MakoShark72
My 72 came with a single horn (and of course the alarm horn behind the left rear wheel well)..I switched to 2 horns.
Not sure but I think some earlier models had 2 horns up front...
Rob
Old Dec 5, 2009 | 07:52 AM
Vette Rookie
Rob
Other than the second horn, what did you have to get? Is their a special harness that you need to get? How do you know what "key" or "tone" horn you have/need to get?
Old Dec 5, 2009 | 08:15 AM
GREGG-73's Avatar
GREGG-73
The part number on your existing horn will identify the tone. With only two tones available...this should be very easy to I.D. Depending on whom you order the additional horn from, they should be able to help with what horn you need, and the harness as well.
Old Dec 5, 2009 | 08:52 AM
Alan 71's Avatar
Alan 71
Hi VR,
I believe 70 was the last year for 2 horns. #245 low note, pass side; #246 high note, driver's side.
71s and 72s had 1 horn, #245 in 71 and #032 in 72. The horns were date coded too.
These numbers may help you determine what you have in your 73.
Regards,
Alan
Old Dec 5, 2009 | 08:56 AM
BKarol's Avatar
BKarol
http://corvette-world.com/corvette_1...ette_horns.php
Old Dec 5, 2009 | 08:58 AM
RMS73's Avatar
RMS73
The 73's came with one horn and the 74's came with two horns. You can get the wiring harness to adapt a second horn from most parts vendors. I believe the 74 horns are P/N 049 and 038.
Roger
Old Dec 5, 2009 | 09:48 AM
Vette Rookie
Thanks, guys for all the information. I would have never guessed there would have been that much difference between the years.
Old Dec 5, 2009 | 09:59 AM
MakoShark72
The original horns, I'm told, are very expensive and hard to find. My '72 did not have the original horn, so I just headed down to NAPA and bought 2 new aftermarket horns. They come with mounting brackets, and I just made my own simple wiring connection to the original horn wire.
"They" say..the horns need to be 2 notes separated for good tone (whatever the heck that means)!!
Rob
(tone deaf from 25 yrs of jet noise!)
Old Dec 5, 2009 | 11:26 AM
vettekid333's Avatar
vettekid333
2024 C3 of the Year Finalist - Unmodified
I learned something new today. I did not know about the horn thing. they must have been trying to lesson the weight for performance in 71 and 72 LOL
To 1 Horn, 2 Horns?
