69 Corvette Glove Box?
Old Dec 6, 2009 | 10:10 AM
mskvettefan's Avatar
mskvettefan
Default 69 Corvette Glove Box?
Has any one ever attempeted to remove the map pockets and add or modify a glove box in it's place in early C3 cars? Sorry Purists...
I am not sure how much space there is behind the pockets but I would think a shallow golve box could be created and installed.
What are your thoughts?
Old Dec 6, 2009 | 10:18 AM
Ravine Speed's Avatar
Ravine Speed
Seems to me that first, the space that you would be able to add would be very limited, second, it would probably look very "Bubba-ish", and third, it would be a tremendous amount of work for seemingly very little gain.
Why do you want to do it anyway? It's not like you're going to be able to fit your golf clubs in there.
Old Dec 6, 2009 | 10:57 AM
mskvettefan
True, and it would have to look professional because the Bubba Look is not what I apspire for... but I am not even comfortable keeping the insurance and owers card in these pockets, so it would not have to be deep, just enough to keep the necessary stuff in.
Old Dec 6, 2009 | 11:11 AM
Alan 71's Avatar
Alan 71
Hi MV,
Have you thought about keeping those papers in the lockable center compartment behind the seats. I bet that's what Chevrolet intended. In not as though you need easy access to them, hopefully you'll NEVER need them.
Regards,
Alan
Old Dec 6, 2009 | 11:14 AM
Ravine Speed
Why don't you use the rear compartments for that stuff? There's plenty of room and my original '69 has the lock and light on the middle one which is perfect for the paperwork. The passenger side compartment can easily be expanded if you take out the tray and stow the jack somewhere else (like up under the rear fender with a bunge cord). You could clean it up, paint it, maybe line it with some vinyl and put a bunch of stuff in there.
I'd avoid cutting up the dash at all costs, but I am more of a purest...
Old Dec 6, 2009 | 03:51 PM
vettebuyer6369's Avatar
vettebuyer6369
As another purist, I agree it would be a pretty awful idea, both from an aesthetic viewpoint as well as trying to explain it when the car was for sale. Especially when the center compartment was made for such things as car-related documents.
However, if you insisted on doing such a thing, I would imagine the best way to go about it would be to simply remove the map pocket side of the dash, and replace it with a cut-out section of the RH side of a donor 78-82 dash, complete with glove box.
I would imagine some careful attention to detail might reduce the Bubba factor. A little.
Old Dec 6, 2009 | 04:04 PM
KTKelly's Avatar
KTKelly
I don't think there would be much space, but I see no reason you shouldn't give it a try....
After all, it's your car....
Why not???????
Old Dec 6, 2009 | 06:32 PM
corvetteload's Avatar
corvetteload
Why?!?!?!?!?!?!?!?
Old Dec 7, 2009 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Up to you, but there is very little to no space behind the dash pad. You're up against the heater/defroster box is a heart beat.
My advice would be to learn to love your map pockets.
To 69 Corvette Glove Box?
