A6 Compressor Size...Any difference?
Old Dec 6, 2009 | 11:08 PM
CCrane65's Avatar
CCrane65
Default A6 Compressor Size...Any difference?
My '72 has a compressor from a Buick based on the label information on it.
I bought one of those clutch shields to keep oil from being slung on the underside of the hood. Problem is anytime I turn the heat or A/C on the compressor clutch hits the shield and makes a ton of noise. You can see on the underside of the shield where it's been scraping.
If I bend it so that it doesn't make contact when the compressor is in use the outter end of the shield hits the front and rear corners of the hood where the clutch/pulley relief is.
What's the deal? I see lots of people using these things. Is my compressor larger than the original one that is supposed to be in there?
cc
Old Dec 7, 2009 | 08:00 AM
markdtn's Avatar
markdtn
I am not aware of any physical differences in the size of the case. however there are sone differences in the size of the clutch over the years and brands.
Old Dec 8, 2009 | 10:01 AM
CCrane65's Avatar
CCrane65
So maybe my compressor shield may be different from what others have bought?
cc
Old Dec 8, 2009 | 10:21 AM
Ganey's Avatar
Ganey
Most A6s are 12.6 c.i. except for Corvette & Corvair which used 10.8 c.i. models.
Old Dec 8, 2009 | 10:52 PM
CCrane65's Avatar
CCrane65
Aha, so my compressor is too big.
I think I'll try to modify the shield. Much cheaper than replacing a working compressor.
cc
To A6 Compressor Size...Any difference?
