missing fiber 0ptic
Old Dec 10, 2009 | 07:00 AM
joe71topless's Avatar
joe71topless
Cruising
Default missing fiber 0ptic
Hello all,
I have 1971 stingray. Unforunately, the fiber optic cable seems to be missing on the passanger side. If possible, where can i find fiber optic cable. Are there any substitutes from another car that I may possibly use?
thanks
joe
Old Dec 10, 2009 | 08:21 AM
bluthundr's Avatar
bluthundr
You can get it from most of the vette vendors, here is what Zip has - http://www.zip-corvette.com/ProductS...%20fiberoptic&
Old Dec 10, 2009 | 09:18 AM
7T1vette's Avatar
7T1vette
Is part of the cable missing or is it just not working on the right side?
Old Dec 10, 2009 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Passenger's side what? Headlight? Parking light? Taillight? If you R&R the wiring harness at each light, you are likely to find at least part of the missing FO cable.
Have you cleaned the FO lenses at the lamps and the console? They get dirty over time.
Old Dec 10, 2009 | 01:01 PM
joe71topless
Cruising
Default joe71topless fiber opthic
F . O .that is missing is the front passenger headlight . Hi and low beam. also parking light and signal .I see where the drivers side F. O. comes from.Do i start looking from there? cleaned all F.O. the rest work great . thanks for the help Joe 71 topless .NJ.
Old Dec 10, 2009 | 08:15 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The forward lamp harness is wrapped and contains both electrical wires and fiber optic cables. If the 3 passenger side FO cables (hi beam, low beam and turn signal/parking lamp) are not there, they must be cut/broken and the ends located back in the wrapped harness somewhere. You do realize the headlamp FO cables are in the center of the electrical connectors?
FO cables can be successfully spliced together...cut the ends square with a razor blade and connect with a short piece of very small vacuum hose, then cement the ends of the hose to the cables to prevent pullout. I am sure somebody like Lectric Ltd, Paragon or Ecklers sells the cables with connectors for the lamp ends. Make sure to install the little black rubber collars when attaching the combination plug to the headlights.
Your other choice is to buy the entire forward lamp harness and it is a PITA to install...especially the FO cables thru the firewall, up to the top of the dash and down into the console indicator panel. I had to drop the steering column, instrument panel, gauge panel, remove the radio and disconnect the center console. Direct from Lectric Ltd, $199.
Old Dec 11, 2009 | 12:09 AM
vettebuyer6369's Avatar
vettebuyer6369
Need a repair section?
Old Dec 11, 2009 | 10:00 AM
joe71topless
Cruising
thank you for the information. I will see if i can find FO in the harness. and go fron there.will let u no.thanks again Joe
Old Dec 12, 2009 | 05:45 PM
vettebuyer6369
Does this mean, "you know?"
Old Dec 14, 2009 | 07:13 PM
joe71topless
Cruising
still dont no .i haventhad time to find the problem .hope tomorrow .i will cut back on harness and hope to find FO. im thinking if i cant find FO. i will think about getting a new harness from zip thanks Joe
Old Dec 16, 2009 | 07:42 PM
joe71topless
Cruising
i cut back on the harness.but didnt find anything .too many wires. i cut where the wires go to the drivers side.then i see where the wire goes to the passangers side. a thiner harness .is that where i look for the FO .that goes to head light and turn sig. thanks Joe
Old Dec 16, 2009 | 07:51 PM
Faster Rat's Avatar
Faster Rat
The forward lamp harness plug connects at the firewall, below the steering column, along with the engine wiring harness plug. There should be a fiber optic pigtail that breaks out before that plug and goes thru a grommet in the lower firewall, closer to the fender. That pigtail should contain all 6 fiber optic cables. If they ain't there, they probably ain't anywhere. If they are, then go forward 'til you find the missing ends. BTW, if you decide to put this harness back together, don't wrap it back up with sticky electrical tape. Doc Rebuild sells the non-sticky wrap that these factory harnesses came with.
Old Dec 16, 2009 | 08:33 PM
joe71topless
Cruising
looked in the car near steering post .i see a big harness that breaks off and goes to a plug that goes thru the firewall.i see where they come thru . under the master brake cyl. about 7 inches from steering post going to fender there looks like a lot of wires. and then they get wraped up and they are hard to follow at that point.But i have drivers side that the FO works on the consold .it lights up. so i am probley looking at the correct wires.will try tomorow.
Old Dec 16, 2009 | 08:56 PM
Faster Rat's Avatar
Faster Rat
I'm just saying that if you are missing the 3 passenger side fiber optic cables, they are probably only missing in the engine compartment somewhere...no need to be looking inside the car. That harness only runs forward on the drivers side, breaks out to the drivers headlamps and turn signal, then continues on to the passenger headlamps and turn signal. Don't be messing around with the electrical plug at the firewall, unless you want more problems.
Old Dec 17, 2009 | 09:56 AM
Easy Mike's Avatar
Easy Mike
The remnants of the missing right side FO will almost certainly be in the wire bundle for the right side lights. The FO stuff is black sheathed standed FO cable. All the electrical stuff is colored wire. You should be able to determine FO from wiring.
Post some pics.
Old Jan 15, 2010 | 08:22 AM
joe71topless
Cruising
to all that helped me with the F.O. i thank you. I finely found where it was cut.It was cut about 6 inches from the drivers side headlight . I ordered 13 ft. from a company called street works. I also bought harness tape and light seals. So im in good shape. Thanks again for the good help
Old Jan 15, 2010 | 08:40 AM
Faster Rat's Avatar
Faster Rat
To missing fiber 0ptic
