Big Block Rear Question
Old Dec 11, 2009 | 08:06 AM
movinup's Avatar
movinup
Default Big Block Rear Question
What is the difference between a big block heavy duty rear and a standard rear besides the side yokes?
Old Dec 11, 2009 | 08:56 AM
gerry72's Avatar
gerry72
That's it. Just the yokes. And I believe after 1970, all rears used the cap yokes, so there's not even that difference.
Old Dec 11, 2009 | 09:10 AM
Mike Ward's Avatar
Mike Ward
NO difference. BB have caps, SB have straps.
Old Dec 11, 2009 | 09:51 AM
joewill's Avatar
joewill
rear sway bar also... but this was also on a LT1
Old Dec 11, 2009 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by joewill
rear sway bar also... but this was also on a LT1...
The rear bar is also on F41 and FE7 cars.
Old Dec 11, 2009 | 10:33 AM
Mike Ward's Avatar
Mike Ward
Not correct. SBs had straps on all years.
Old Dec 11, 2009 | 04:20 PM
movinup's Avatar
movinup
Thanks for all of your replys. You just verified what I thought.........
Old Dec 11, 2009 | 04:26 PM
dmayhew's Avatar
dmayhew
It is my understanding that LT-1's only had a rear sway bar if F41 was also ordered.
Standard LT-1 only had the HD yoke caps as standard.
David
Old Dec 11, 2009 | 04:48 PM
Alan 71's Avatar
Alan 71
Hi David,
Did you get an answer from CB on your code variation?
Regards,
Alan
Old Dec 11, 2009 | 04:50 PM
Gordonm's Avatar
Gordonm
David
You are correct. LT1s with F41 had rear bars. The others did not. The LT1 cars also had caps not the straps.
To Big Block Rear Question
