How does your C3 handle?
Old Dec 11, 2009 | 05:31 PM
montez27's Avatar
montez27
Default How does your C3 handle?
When ever I take a tight corner at speed the rear feels like it is STEERING around the corner as well. It doesn't get loose or make any squeeling noise. It kinda feels like it is floating around the corner and then I come out of the corner and it feels the same straightning out. My Vette stays flat and controlable except over med bumps or pot holes, then it gets a little upset.
It is a lot different then my 70 camaro. Both cars have new suspensions set up with a good alignment and new parts. My Vette is an 82 with a stock front end, rear has a hyperco spring, 5/8 sway bar. I have tokiko shocks in the front(I like them)255/45-17, but the rear has the KYB adjust-a-crap (want Bilsteins) 285/40-18.
I am confident with the handling, just wondering how others would describe the handling of their Vettes.
Old Dec 11, 2009 | 07:20 PM
Hootisit's Avatar
Hootisit
I have a 82 with a rebuilt stock suspension. with 7/16 rear stabilizer bar. It handles good, cornering seems alright, but I don,t think it gives me a real feel of the road going straight, it's like it's floating. Maybe I'm just use to rack & pinion steering on my other vehicles....I'm lost in this matter......
Old Dec 11, 2009 | 07:44 PM
nutsy's Avatar
nutsy
its no comparison to todays cars . it handles pretty good but the play in the steering wheel is what i dislike most.
Old Dec 11, 2009 | 07:46 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
It handles like a 40 year old car.
Old Dec 11, 2009 | 10:00 PM
7T1vette's Avatar
7T1vette
Actually, it handles like a nearly 50 year old vehcile. The C3 suspension was essentially unchanged from the C2, so it is 1963 technology in these cars. Now, if you consider that they were 10 years ahead of their time [when new], you are back to a 40 year old technology.
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It feels that way because that's what it's doing. A downside of the C3 rear suspension design is that during hard cornering, the rubber bushings in the suspension all flex in a direction that gives a net toe-out to the outside wheel, and a bit of toe-in to the inside wheel. This is what makes it feel like the rear wants to swing out and pass the front.
The C4 rear suspension is designed to do just the opposite in a corner, which is why a C4 is a lot more predictable when driven at the limit.
Old Dec 11, 2009 | 10:13 PM
Leung's Avatar
Leung
Old Dec 11, 2009 | 10:18 PM
not a '76's Avatar
not a '76
Unpredictably with a nasty tendancy for extreme oversteer.
I was able to fix the 'slop' by tightening the steering box in a manner no one recomends, replacing the rag joint, and the other bushings.
And it has, bilstein sports, and good tires.
Old Dec 11, 2009 | 11:03 PM
montez27's Avatar
montez27
Default poly
Well, I do have all poly bushings as herb adams said the worst thing about this suspension were all the rubber bushings being to compliant during hard cornering, but I guess it wil still have some flex no matter. Also. What about sitting so far back as to be almost at the rear wheels as opposed to my camaro where I am quite a bit foward??
Old Dec 11, 2009 | 11:22 PM
Ironcross's Avatar
Ironcross
It follows the ruts like a pro as if they were made for it......dont even have to steer it, the damn thing goes wherever it wants......hasn`t managed to go around a corner yet though
Old Dec 12, 2009 | 07:31 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I replaced everything that was worn and it handles great...compared to today's cars it's like a Iron on Ball Bearings!:
Old Dec 12, 2009 | 07:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Although I currently own a C-5, which is quite a bit different, my wife owned a '79 C-3 for 18 years. 2-3 years before we decided to sell it, I went through the entire suspension, even though the car was a fairly low mileage vehicle.
I installed new ball joints, tie rod ends, poly bushings everywhere, new shocks, VB&P front coils and rear 'glass spring, and added a rear sway bar. It made quite a difference in how the car handled, due to the poly stuff and rear sway bar, and rode, due mostly to the rear spring.
Old Dec 12, 2009 | 09:30 AM
onehundred's Avatar
onehundred
Da-Fuzz
Mine handles like it is on rails. VBP suspension kit.
Old Dec 12, 2009 | 10:21 AM
Mike Ward's Avatar
Mike Ward
Very true, but the actual design work was done in the late 50's including the weird and wonderful power steering set up. They handle better than any other car of that era!
Old Dec 12, 2009 | 01:01 PM
Ganey's Avatar
Ganey
Great, FE-7 w/ VB&P rear spring.
Old Dec 12, 2009 | 01:25 PM
Steve~74's Avatar
Steve~74
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Like a squirrely 35 year old car.
Old Dec 12, 2009 | 01:35 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I have had the 73 for two years & for two years we have worked on the steering & still has a ton of play
To How does your C3 handle?
Old Dec 12, 2009 | 04:46 PM
phclub's Avatar
phclub
New England Events Coordinator
Default but it is fun
I have a 70 Vert, no power steering, but good alignment. She handles like a 40 year old. I call it the beast, but once I get her out on the highway, it doesn;t matter, the beast is tamed. I'm lovin it!
Old Dec 12, 2009 | 07:05 PM
hwcoop's Avatar
hwcoop
mine is manual steering with a 4 speed. 255-60-15 tires, a little squirrly on truck ruts in the pavement but holy crap it is sure fun on nicely paved windy mountain roads!!
Old Dec 12, 2009 | 10:43 PM
NJVette77's Avatar
NJVette77
Well.....that sums it up right there
