72 vin
Old Dec 13, 2009 | 03:14 PM
mfiles's Avatar
mfiles
1st Gear
Default 72 vin
Can the month and day my 72 was built, be deciphered from the VIN? Also, does anyone reproduce VIN Tags? Mine is kinda of rough.
Old Dec 13, 2009 | 03:32 PM
Alan 71's Avatar
Alan 71
Hi mf,
I don't think you want a repro VIN tag if you can avoid it in ANY way. There are LOTS of serious legal issues with replacing a VIN tag.
The VIN sequence number can tell what month and perhaps what week the car was built by reviewing the monthly production totals for 72.
The build date for the body (which should be within a day or two of the car's build date) is on the 'trim tag' which is pop riveted to the driver's side hinge pillar. The tag also has the code for the exterior color and the color of the interior, along with standard or De-luxe.
The build date code is a letter for the month and one or two digits for the day.
F14 ... January 14th.
Hope this helps.
Regards,
Alan
Old Dec 13, 2009 | 06:42 PM
Duke94's Avatar
Duke94
Also, this site will get the info Alan mentioned.
Gary
http://www.corvettec3.ca/numbers.htm#1976_Options
Old Dec 14, 2009 | 09:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mfiles
...Can the month and day my 72 was built, be deciphered from the VIN?...
Yes and no. You could do the math and get close to an actual date by comparing published production figures.
It's easier to check the time/build date in the upper right corner of the trim tag on the driver's door post. That will give you the date the car passed the station on the assembly line where the tag was attached. The car would probably not have been completed on that day, but it's fairly close to an actual birthday for your car.
Old Dec 14, 2009 | 11:10 AM
Ravine Speed's Avatar
Ravine Speed
As posted earlier, you can do a good estimate of the day yours rolled off by adding a few days to the trim tag date, or looking at the production figures for your month. Also, the C3 Regisry Site has this little program that takes your VIN and spits out a "birthday". It's just an estimate as well, but shouuld get you clsoe. Link follows.
http://www.c3registry.org/index.php?...lator&uid=2683
To 72 vin
