One cylinder low compresison
I am working through all the bugs of my 69 coupe and am trying to deal with a rough idle. I have traced it to significantly lower compression in cylinder number 8. I put compressed air in the cylinder and it seems that the air is seeping out through the crankcase. Adding oil to the cylinder raises compression. I think this all points to bad rings. This is a low mileage car (60k) and I suspsect that rings are stuck with carbon. The car has not been driven in 3 years.
Before I open it up, I was wondering if any of you have tried the various remedies for this. I have seen MMO, AutoRX, Seafoam, GM top engine cleaner etc. Do any of you have experience with this?
I know that many people will add 1/2 a quart of ATF and drive car. A friend also told me to dump some kerosene into cylinder and let it soak - repeating process - then change oil.
Any thoughts?
MG
I would try the simple methods of cleaning deposits out before opening up the engine. You could have a damaged/broken/misinstalled ring in there too. But try the easy stuff, first. It could work.
