my volts are jumping!
Old Dec 14, 2009 | 09:38 PM
ericevil's Avatar
ericevil
6th Gear
Default my volts are jumping!
my volts are running at the regular then every now and then jumping to 17 and all electrical things die but motor still going. when it goes back down a few seconds later all comes back on. any ideas? has a new altenator and battery but maybe they are bad?
Old Dec 14, 2009 | 10:27 PM
72LS1Vette's Avatar
72LS1Vette
I wouldn't suspect the battery but the voltage regulator is certainly something to look at. If it is built into the alternator I would bring it back to wherever you bought it to have it re-tested or replaced. You shouldn't see more than ~14.5 volts from a correctly operating charging system. Depending on what electronics you have in the car you can do some damage from over-voltage.
Rick B.
Old Dec 14, 2009 | 10:35 PM
ericevil's Avatar
ericevil
6th Gear
cool...thats what I was thinking. I read some other info also and some people had a bad new battery and bad new alt. so I was going to replace the voltage regulator first.
Thanks for the help!
Old Dec 14, 2009 | 11:01 PM
oldsarge's Avatar
oldsarge
I don't recall seeing what year the car was, but as mentioned above some regulators are built into the alt. and some are separate. but it does appear to be a regulator problem of some sort.
Old Dec 14, 2009 | 11:04 PM
ericevil's Avatar
ericevil
6th Gear
sorry, Its a 78 so it's built in.
Old Dec 15, 2009 | 12:46 PM
Darrel1's Avatar
Darrel1
I had a similar issue this last summer. Had the alternator checked and they said it was fine- I checked everything. I was then told that the alternator can be bad and the stand that they are checked on may not know it. I think I was told that the regulator and/or some diodes in the alternator go bad and that causes the jumping.
Anyways- I replaced the alternator and all is good
Darrel
Old Dec 15, 2009 | 05:20 PM
jersey68l36's Avatar
jersey68l36
The fact that ericevil mentioned mentioned voltmeter and not ampmeter precluded that the alternator most likely had a built-in regulator. Think by '70 or or definitely by '71, GM was using built-in alternators.
Old Dec 15, 2009 | 07:42 PM
stellar's Avatar
stellar
The rest of elect should run faster or brighter if reg is the problem not quit working. You have a bad connection. Not sure of wiring for that car so check at power junction, possibly at starter post.
To my volts are jumping!
