measurements for body
Old Dec 15, 2009 | 08:54 AM
69ragvette's Avatar
69ragvette
Default measurements for body
what is the method for body to frame alignment ? http://i681.photobucket.com/albums/v...g?t=1260885067
Old Dec 15, 2009 | 09:02 AM
69ragvette's Avatar
69ragvette
Default body measurements
bodyto frame measurements
Old Dec 15, 2009 | 09:13 AM
champs65's Avatar
champs65
If you have a '69 chevrolet chassis service manual, there is a frame chart in there which shows the height, spacing, and reference points of all the body mounts from a common point.
Old Dec 15, 2009 | 09:18 AM
69ragvette's Avatar
69ragvette
Default body
I have a large three ring binder it looks like a 69 corvette assembly manual for factory specs?
Old Dec 15, 2009 | 09:19 AM
champs65's Avatar
champs65
1969 Model specs as per GM manual:
http://www.digitalcorvettes.com/foru...ad.php?t=87024
Old Dec 15, 2009 | 10:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 69ragvette
...what is the method for body to frame alignment?...
What are you wanting to do?
Old Dec 15, 2009 | 07:36 PM
69ragvette's Avatar
69ragvette
Default body
I need to set the body on the frame,before I weld the cage I need to set the frame mounts in the proper position as the rear mounts were rusted away and the body was cracked. it looks as though the rear of the body is all the way to right
To measurements for body
