high beam indicator?
Old Dec 17, 2009 | 10:41 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default high beam indicator?
Do C3's have a high beam indicator? mine doesn't. Didn't know if it's burned out or didn't have one.
Old Dec 17, 2009 | 11:09 PM
CoolShark's Avatar
CoolShark
They have 'em. Yours must be burned out.
Old Dec 18, 2009 | 03:36 AM
BenUK's Avatar
BenUK
There's a blue high beam indicator lens within either the tach or speedo face on my '76. (Can't remember which.)
Old Dec 18, 2009 | 03:57 AM
shrekviper's Avatar
shrekviper
My '69 has a blue "BRIGHT" indicator at the top of the Speedometer and a red "BRAKE" indicator at the top of the Tachometer.
Old Dec 18, 2009 | 09:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Attfay Elleybay
...Do C3's have a high beam indicator?...
Yes. Your tell-tale lamp is probably burned out. Check the owner's manual, but it's probably at the top of the speedo.
Old Dec 18, 2009 | 01:46 PM
Domer's Avatar
Domer
They have them - my '77 does...
Domer
Old Dec 19, 2009 | 10:35 PM
Go Vette's Avatar
Go Vette
I have the opposite problem. My high beam indicator is very bright, but the rest of the bulbs are dim or out! lol Oh yeah, the seat belt light is bright too. It always comes on when I use the headlights...
Old Dec 20, 2009 | 09:33 AM
joewill's Avatar
joewill
when I had my dash apart fixing the heater ducting issues, I studied closely the wiring diagram and the wires themselves... take a hour or so to study the wiring diagram and you will easilly see how it all works and where the indicator is....
it is usually the bulb or the bulb is pulled out of its socket... easy fix but you have to have pretzel fingers to get up there it and get to it..
the assembly manual and the wiring diagram are your 2 best friends for your corvette..
Old Dec 20, 2009 | 05:11 PM
C3smallblock's Avatar
C3smallblock
I'm going through the same problem at the moment. I could not get my hand far enough behind the dash to replace the bulb without taking anything out. The left side of the dash needs to come out, and to do that the steering colunm needs to come out. I am going to replace all my dash bulbs with long life LED ones so I dont have to do this ever again (I hope).
Cheers
Kev
Old Dec 21, 2009 | 12:00 AM
tigers123's Avatar
tigers123
Cheers
Kev
My 1974 the steering column did not have to come out. Just take the two bolts holding the column in front out and let it drop down. You should be able to take dash out. Remember the top dash must be removed as well.
Old Dec 21, 2009 | 03:06 AM
C3smallblock
Oh, that gives me a bit more hope. So how do you remove the top dash?
Kev
Old Dec 21, 2009 | 10:35 AM
tigers123's Avatar
tigers123
You have to remove the pads from the side pillars. And then you remove the screws angled into the upper dash pad from the front dash all the away across. Then you can slide the upper dash up and out. But be careful with the upper dash pad as it may be brittle. Don't get with rough with it or push too hard around speaker holes in the upper dash pad . Treat it with kid gloves. Once it is removed you can take your front dash out. If you take the center bezel out for the guages be careful with it as well. As it is a thin piece as well. Also be gentle with the vents on the front dash as the plastic behind it is flimsy at best. It is not as bad as it seems , but you don't want to do this every day either. Also it helps to have room temperature to handle the parts. Remember some of these parts are plastic and 30 years old. Also while your at it look in the catalogs of corvette parts, and buy the bulb kit. Replace every bulb under there if your going dash surfing. Some guys use led's, but I heard you might have trouble with the dimmer. Also if your dimmer is bad replace the light switch as well. You won't have a better time to so this than when you have the dash out.
Old Dec 21, 2009 | 12:41 PM
C3smallblock
Thank you so much for the detailed info, that is going to be my boxing day project, new bulbs all round
Interesting about the LED bulbs, I live quite close to an auto store, so I may get one, see if it works with the dimmer and if so, go back and get a bunch, if not go for OEM ones. Thanks again for the info.
Kev
To high beam indicator?
