Electric Headlight Pop ups
Old Dec 21, 2009 | 06:40 AM
briaineo's Avatar
briaineo
Default Electric Headlight Pop ups
Has anyone attemped to convert the old headlght system to electric? Theres conversion kit out the for $999. Has anyone done a Diy job on 'em?
Old Dec 21, 2009 | 09:34 AM
Artsvette73's Avatar
Artsvette73
Diy will not be cheap either.You can rebuild a vac system for less than the electric conversion. I have done the electric to my 73 and it works the same as the original vac. system on my 77. Only at a diffrent rate of speed.
Old Dec 21, 2009 | 09:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Someone did a conversion a while back using Camaro/Firebird motors. Search the archives of the Corvette magazines. One of them did an article on the conversion; can't recall whether if was Corvette Fever or Vette.
Old Dec 21, 2009 | 09:57 AM
SteveG75's Avatar
SteveG75
The $999 kit is way over priced. Do a search for "Killer Lights" and you will find a kit that allows you to utilize C4/F-body electric motors. Much better design.
Only reason to convert is if your engine doesn't produce enough vacuum.
To Electric Headlight Pop ups
