Graphic decision
Old Dec 24, 2009 | 12:19 PM
Stingxray's Avatar
Stingxray
Default Graphic decision
Ok:
Please Help me decide . Attached are the 3 cad programs we've come up with for the EFI filter lids. Witch one ? Or perhaps Your suggestions on something completely different & unique.
Will take everyone's advice and use the Original FI valve covers. Thanks for the help everyone ........... GRA3
Old Dec 24, 2009 | 12:56 PM
72LS1Vette's Avatar
72LS1Vette
I like the 2nd pic with the blockier letters better. How about that one with the letters and lines in solid red?
Rick B.
Old Dec 24, 2009 | 01:16 PM
Stingxray's Avatar
Stingxray
Default lettering
Perhaps " Hilborn
Fuel Injection "
Would look better than EFI ? I'm also looking for the FONT for the Corvette Script on the valve covers. I believe its Harlow Script ?
Old Dec 24, 2009 | 03:19 PM
Alan 71's Avatar
Alan 71
Hi Sx,
I think the grooves that CAN be continuous, should be continuous, to match the fins on the valve covers, regardless of what font you decide use.
Great looking motor!
Merry Christmas!
Regards,
Alan
Old Dec 24, 2009 | 03:46 PM
Smadoo's Avatar
Smadoo
It really depends on if you want to try to make it look similer to OEM.
If you want it to look like it could have come from chevy use the valve cover script.
But if you want more of an aftermarket look then I like the Block letters.
Regardless of the font, definitely make the grooves continuous.
Old Dec 24, 2009 | 07:19 PM
onaqwst's Avatar
onaqwst
make hilborn in the same line thickness than the grooves and have the grooves intersect the far left/right letters...
----hilborn-----
Old Dec 24, 2009 | 07:23 PM
glassman74's Avatar
glassman74
St,
Omit efi.Put Hilbor in center. Block letters. Grooves cont.
What cad program are you using?
glassman74
Old Dec 25, 2009 | 06:21 PM
Stingxray's Avatar
Stingxray
Default Go to the source
Well well ........look what I found in the front of the Hilborn catalog ! This might work!!
Old Dec 25, 2009 | 07:59 PM
bobbarry's Avatar
bobbarry
I'd go with those fonts, two lines with the Hillborn slightly larger, with the fins and script RAISED rather than milled into the surface (should be easy enough if you're just running it through a CAD/CAM machine), to better match the valve-covers, and texture the surface to match the valve-covers as well.
Old Dec 25, 2009 | 08:07 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Perhaps " Hilborn
Fuel Injection "
Use a script like the "Corvette"
Old Dec 26, 2009 | 12:25 AM
Eddie & the Cruisers's Avatar
and on two lines
Old Dec 26, 2009 | 08:21 AM
NMsharkracer
Originally Posted by Eddie & the Cruisers
and on two lines
definitely
Old Dec 26, 2009 | 08:30 AM
3JsVette's Avatar
3JsVette
and on two lines
Originally Posted by NMsharkracer
definitely
It would give the look of "period correct". Very nice work by the way. Truely a great looking engine.
Old Dec 26, 2009 | 11:12 AM
turbojet's Avatar
turbojet
[/QUOTE]
Old Dec 26, 2009 | 11:41 PM
Stingxray's Avatar
Stingxray
Default How's this ?
Ok............................... So will this due ?
Old Dec 27, 2009 | 11:17 AM
bobbarry's Avatar
bobbarry
Much Better.
If you're still open to suggestions:
* I like the idea of running the ligatures into the fins, so that the beginning of the "H" and the end of the "n" run into a fin, as well as the beginning of the "F" and the end of the last "n".
* I would make the "Hilborn" larger, so that it is the same length as "Fuel Injection", and I would make it as tall as three grooves, rather than two, perhaps dipping in to eliminate the fin dividing them through the middle.
* I think it would match the valve-covers better if the fins and letters raised as though it was a casting (very classic) rather than milled as grooves in a flat surface (very early-90's).
Old Dec 27, 2009 | 03:02 PM
Stingxray's Avatar
Stingxray
Default Keep it ideas coming
You've all had great Input here.... Thanks . My Buddy Mark (the Machinist) is very patient, I think it's gonna turn out much better than we'd imagined. Hope he doesn't grow tired and say " It's gonna cost you $$$ more. I think the raised machined fins are do-able , but not into the lettering. To link the letters into the straight lines, It would have to be ball milled together. But I'm gonna ask him anyway. Cross your fingers
To Graphic decision
Old Jan 4, 2010 | 04:06 PM
Stingxray's Avatar
Stingxray
Default Progress
Hilborn Billet filter attachment's are done. Next are the bases ....and then the Tops. The Fins will be more money ..but not much more....
Old Jan 4, 2010 | 04:08 PM
bobbarry's Avatar
bobbarry
I can't wait to see the finished product.
I also can't imagine what kind of check you're going to have to write for all that...
Old Jan 4, 2010 | 04:18 PM
Stingxray's Avatar
Stingxray
Default $$$
Well Bob ...It' s still less than my factory 63 FI's unit's to rebuild & tune. And so much more fun Side note : Just One Hilborn cylinder's butterfly is bigger than the Fuelie's for the whole motor!
