Steering wheel play
Old Dec 28, 2009 | 04:33 PM
paulebrown's Avatar
paulebrown
Default Steering wheel play
Anyone got an opinion as to how to cure play in steering wheel of 72 conv. She has about 170k miles, mostly rebuilt, but steering is original.
Thanks for any help
pb
Old Dec 28, 2009 | 09:01 PM
mds3013's Avatar
mds3013
Use the Forums search feature and search for Jim Shea. He is the steering Guru on the Forum. There should be plenty of info to get you started. mds...
Old Dec 28, 2009 | 10:00 PM
bj1k's Avatar
bj1k
Thanks for any help
pb
The first thing to do is check for a bad rag joint on the steering shaft. With that many miles on it , the joint is probably ready to break if it hasn't been replaced.
Old Dec 28, 2009 | 10:19 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Have someone sit in the driver seat and turn the steering right & left. You look at the rag joint to see any play. If there is no play in the rag joint, then it is the steering box or something in the steering assembly.
Old Dec 29, 2009 | 09:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take the lash out. That will tighten her up a little. Just the same, 170K is a lot of miles.
Old Dec 29, 2009 | 10:02 AM
paulebrown's Avatar
paulebrown
Thanks Guys,
Much appreciated.
pb
To Steering wheel play
