What does "streetability" really mean??
But really, I only meant to ask about the powertrain. I am considering an engine project for next year, and that's the root of my quest for knowledge..
I have a new VBP sport suspension, a sturdy 2004R, a 2400 (or maybe 2800, I'd have to check) converter, Hooker sidepipes, stock 3.08 rear. Strictly a fun street car.
I want to take extended trips in it, as well as drive it down to Starbucks to show off..I want the best compromise between low/med power/tq and .....you guessed it, streetability!!!
I already have the creature interior comforts (T/T, PW, A/C, tunes, etc) so I really will be asking (in the future) about powertrain...
I will have a budget of around $5k, so my choices would be to upgrade my ZZ4 (top end), a crate 383 or 400, or build one myself...
Even though I havent finished my resto-mod yet, I'm just trying to get smart early..!!
Thanks for everyone's input!!
Rob
So while the car is faster when you've got your foot all the way to the floor and the engine is wailing and the tires are screeching and the exhaust is bellowing, the car is actually slower when you've got your foot a 1/4-way to the floor trying to go from 25mph-40mph in top gear. If you've ever driven a car with a slipping clutch or transmission, that's what a high-stall converter feels like at part-throttle and low-rpms. Now of course, you could always just floor it anytime you want to gain any speed, which is lots of fun, for about the first five minutes in traffic, but after a while, treating your gas-pedal as an on/off switch gets tiring.
For your car, If you're going with an OD transmission, I'd suggest steeper rear gears (3.73's or numerically higher) and a tighter converter (stock or no more than 2000rpm stall) to maintain that low-speed, around-town throttle-response.
The car that my '71 replaced was powered by a race motor that came out of a sand-dragster: ~470ci, 110-octane drinking beast without enough vacuum to effectively serve the power brakes and that was difficult to keep running cool for more than 20 minutes at a time. It was a lot of fun to walk it off the line and then lose traction again at 40mph in first gear when it started to get up on the cam (it had 2.56 rear gears), but with its chokeless Holley carb, just getting it going was an adventure, and with the Purple Hornies header-mufflers, it was one that the whole neighborhood got to hear (whether they wanted to or not). I'd gotten used to popping it into neutral and blipping the throttle to build some vacuum for the brakes before every stop-sign, but again, it was just something else to think about. Plus, living in a city I start endangering others if I drove the thing at more than 1/3-throttle for a few seconds at a time. With all the hassle, I never drove the thing much at all.
OTOH, I drive my base-motor '71 every chance I get, and at basically the same speeds as my race-motor monster; it's a lot more enjoyable overall.
Ran on pump gas, did not overheat & lic. plates.
Very streetable.
Others would disagree, not a car for most drivers.
People that followed (w/ me waiting on them) complained that min. speed was 40 & normally 80+.
Rob So what does that mean- in & out w/ the clutch to keep running at low speeds, high rpm high power setup.
So for streetability, one would do a setup (CAM, ETC.) for the rpm range one uses.
Lots of good thought-provoking info here.
I DO NOT intend to "race" the car. I drove it for the first time yesterday, and thanks to you guys, I am finally understanding the concept of "stall", with respect to the converter. I think I have a 2400 rpm converter, but will check with the folks who built my transmission.
I certainly dont want to have to go to mid-throttle to get from light to light!! Not with the Hookers and capped STS baffles. I dont commute to work, this will be a year-round driver, and I want it to NOT be a pain to drive around town.
Someone above mentioned gas mileage. That is important to me as well. I have thought of going to slightly steeper gears (currently stock 3.08) but I am wondering how far to go without sacrificing fuel mileage TOO much. And yes, I know its all a trade-off, and its hard to have it both ways! I am familiar with the RPM tables on BTO's website. I should be running around 1700 RPM at around 60 with my 2004R and 3.08's and 60-series tires. That seems great for cruising, but still seems a little low to me (but what do I know??) I am clueless as to whether my mid and top end (for passing, merging, etc) hp/tq will be "acceptable" with my (355 crank hp/405 crank tq) ZZ4 and my trans/rear. I'm sure it is more than enough!
Just looking for a suitable compromise... Maybe I already have it, time will tell.
I am jumping the gun a little, but have read that some folks are "disappointed" with the ZZ4 performance. I'm sure it will make me grin!!
This forum is about getting smarter. I'm trying, so thanks for everyone's input!!
Rob
Honestly, 1700rpm is going to be LUGGING that engine; heck, with my chipped Powerstroke diesel, 1700rpm is almost lugging the engine!
And as a rule, you don't want your cruise rpm to be lower than your converter stall-speed; even if you alleviate the overheating problem (due to the constant slip from being below the stall-speed) through a lock-up converter, you're going to get a "lag" everytime you move the throttle with that combination and short of pegging the gas every time you want to change speed, your car will feel about as powerful at part-throttle as a 1996 V-6 Taurus while cruising down the highway.
A 2200-2500rpm cruise-speed is likely to be far more reasonable for a motor like that, and an 1800-2000rpm stall converter would complement that nicely.
And lower-rpm is not always better for fuel-mileage; if you're lugging the engine, you have to give it more throttle to maintain that speed than if you geared it to let the engine work in the fat part of its torque-curve, where you can maintain speed with less throttle-opening.
The best thing would be to consult your engine's dyno chart, and try to get your cruise-speed not too far below your peak-torque rpm; that would improve "streetability" as well as fuel-mileage.
But I don't think you'll be falling into economy-car mpg's, no matter what you do...
I agree with what others have said, but in my opinion it's terminology.
The term "streetability" is a bit misleading as it kinda incorporates and infers "practical", "drivability", and "street legal" all together.
Basically how tame vs wild a car is.
Rob
You need to consider what your normal usage will be and what expectations you want out of the vette (i.e. performance, handling, sound, fuel economy, comfort, etc..). More specifics and details help us help you with future upgrades.
If you start upgrading you 'may' start losing its "streetability", especially if you are planning on taking extended trips with it.
I meant I have never really DRIVEN my car, or any high performance (that's a relative term of course!) car for that matter. So I really have no baseline experience to draw from.
So here's what I'm after..
-Decent idle..I dont want to have to keep my foot on the pedal to get 'er to run...
-Ability to drive around town without sprinting from light to light...
-Smooth linear acceleration...
-Strong noticeable torque during low and mid rev acceleration...
-Ability to effortlessly accelerate and pass from 50-60 up thru 80-90...I really dont see myself driving this 40 yr old car much faster than that!!
-"Decent" gas mileage...high teens+ which is why I went with the O/D transmission and kept the 3.08....
All the other "creature comforts" I have pretty well covered..
Thanks!!!
Rob
Want a little extra performance uncap those STS's, that's what I did with mine.
Rob
The VERY short drive yesterday didnt tell me too much. I was basically checking out braking, tracking, steering center, etc. so wasnt paying too much attention to rpms/movement.
FWIW, my ZZ4 was always planned to be an interim motor. I got a screaming deal on it from a kid who was getting out of the army and had to get rid of it (brand new, never uncrated).
My goal is a "streetable" (here we go again
) 450hp/450tq +/- good-mannered motor. I also have had plans to eventually go to a lower rear gearing, bumping down a couple of notches for better acceleration and to get more into the power band of the motor.Now that I just bought a C6, the 72 is taking on more of a FUN role, and gas mileage is definitely slipping down the "important to have" list!! Maybe a ZZ502 is on the horizon! (just kidding...probably)
Thanks for the discussion!!
Rob
This morning I got a video response on my youtube site, thought I'd share it:
Not sure about that wing though...
My 79 is a 406 powered cruiser,10+compression starts on the first try without pumping the gas,does not overheat,idles at 700 in gear with the air on and runs 12.80 in the 1/4 mile.Appx 460 hp/475 tq
Aluminum heads,hyd roller cam and a 2004r overdrive with a 2200 converter.I can drive it daily or to Cincinatti(125 miles) with NO issues or need to carry a tool box.......
Level of motor tuning, suspension tuning, what an idividual would put up with on a normal bassis are factors of streetability.
My wife did a dailey 25 mile commute for about 2 weeks in my solid roller cammed 72 LT-1 Vette with 4.56 gears. The traffic was stop n go so, she really liked having the 4.56 gears, that's why I love her so much! My kind of gal
I assume it relates to idle, stall speed of the converter, hp/tq...?
What exactly does a car exhibit when its not very "street mannered"? Is it idle quality, or acceleration, or too much torque, or just what???
Since I may be looking for a bigger motor for my "not yet finished" 72/ZZ4/2004R/3.08 Vette, I'd like to know what to start thinking about...
Just food for discussion!
Rob
