Patriot Side Pipe Height Problem.
Old Jan 11, 2010 | 01:15 AM
avner's Avatar
avner
Default Patriot Side Pipe Height Problem.
Problem Solved go to the thread end
My headers are Hedman# HED-68286 (3" collector) and for the side pipe I have the patriot# PTE-H1060.
The original installation of the patriot pipes is under the frame and it's too low, and also the 90* pipe adapter go from 2" to 3".
I want to solved those two problems by:
1. Raise them by S-Band pipe, 4" offset.
2. Keeping the 3" diameter all the way.
Hedman Headers: http://www.summitracing.com/parts/HED-68286/
patriot SidePipe: http://www.summitracing.com/parts/PTE-H1060/
For the S-Band pipe: I used two pieces of 45*.
Avner
Old Jan 13, 2010 | 02:25 AM
avner's Avatar
avner
TTT
No one ever think/make/fix those problems?
Avner
Old Jan 13, 2010 | 08:42 AM
cargo247's Avatar
cargo247
mine are a little low as well, the price was right for the Patriots to see if i lkied sidepipes and yes i do so now i am looking at some hookers and they will fit higher.
Todd
Old Jan 13, 2010 | 10:43 PM
bj1k's Avatar
bj1k
1. Raise them by S-Band pipe# FLO-15907, 4" higher.
The problem is that they sale the S-Band pipe# FLO-15907 in set of 6 and I need only 2.
Do you know where I can by only 2 pipes like the S-Band pipe# FLO-15907?
Or maybe someone in the forum has 2 spare of those S-Band pipe# FLO-15907.
S-Band pipe: http://www.summitracing.com/parts/FLO-15907/
Avner
I had Patriot side pipes on my 68 for a while, they would drag on everything , even the slightest rise in the road. You can see in the picture in my avatar how low they sit. They sit under the frame and the stock sidepipes sat more along the rocker panels. I am in the process of installing original style sidepipes from Sweet Thunder. I bought the ones that come without the connecting pipe that goes over to the engine. You use these when you have headers. You have your own pipes made up going over to the headers. The mufflers themselves are only around $350. Can use fiberglass covers.
Old Jan 14, 2010 | 01:43 AM
avner's Avatar
avner
Because of low installation of the patriot mufflers I want to raise them up by putting the S-band pipe in the front of the patriot muffler, the S-band have a 4" offset and I will have only one low point near the front where the elbow ~90* pipe go to the header collector so it will seat like the hookers.
I tried to show how it will be in this pic'
Avner
Old Apr 11, 2010 | 08:24 AM
dmeesq's Avatar
dmeesq
http://forums.corvetteforum.com/c3-g...tall-pics.html
here is my install of patriot lake side pipes
Old Apr 11, 2010 | 08:45 AM
avner's Avatar
avner
How did you connect the 4 to 1 at the pipe that come from the engine, I saw that you have short headers and single pipe go from them?
Old Apr 11, 2010 | 10:09 AM
seventysixvette's Avatar
seventysixvette
Avner, I hand built my sidepipes, but I liked the Patriot heat shields so I used them. I'm also running the exact side-dump headers you are. I mounted my sidepipes just as high as I could without hitting the door, and just as tight to the frame as is humanly possible. They've never scraped or bottomed out. I just used 3" aluminized tubing with 3" auger baffles, but I don't see why one couldn't use the chrome tubing in the kit.
I know the engine likes to move around when under acceleration so I used a couple 3" flexible exhaust couplers I bought off e-bay. The exhaust dumps out the headers, runs through the couplers makes a not quite 90 degree mandrel bend and runs straight out the back through the baffles.
The jury's still out on the sidepipes, and I didn't want to commit to them just yet so I made the whole set up removable with no welding on the frame. there's a couple slotted holes in the frame, so I made a couple T bolts from some 1/2" carrige bolts to hold the whole thing on.
The whole thing could be prettyed up. The use of chrome tubing would look nice and make the perfect set of sidepipes...
John
Old Apr 11, 2010 | 12:05 PM
avner's Avatar
avner
John
I have the 90* chrome elbow but I didn't use it because the angel that I have from the Hedman collector to the side pipe is ~100* and it's go from 2" to 3" so I will made one piece include the 90* elbow & the S pipe 3"in / 3"out, and I will send it to chrome plate, also I put on both Hedman collector a Hedman reducers 3"in / 3"out - HED-21134, it have oxygen sensor bung for the feature.
Do you know a good place for the exhaust chrome plating?
Avner
Old Apr 11, 2010 | 07:12 PM
Gilded_Splinters's Avatar
Gilded_Splinters
I took mine off today, which was the plan all along while I had it in the air doing a million other things.
The car will become beached on a ripple in the road.
I'm planning on putting a chambered system in ASAP. I was looking at Mid America Motorworks.
Old Apr 11, 2010 | 07:20 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
contact Mike Allen at allencorvetteexhaustsystems.com. I got a ss chambered exhuast (2 chambers per side), along with all the mtg brkts and shipping for $510.
Old Apr 11, 2010 | 09:47 PM
dmeesq's Avatar
dmeesq
Only one inlet is functional, the other three are dummys, but the one is plenty and they are only 280$ with mufflers so if they rust or pit in 5 years its easy off easy on with a new set.
seventysixvette
Avner
I'm sorry I don"t. The only thing I've ever had chromed was the springer I put on the front of my old ironhead. I had that done locally. There's bound to be many competant chrome shops that could handle exhaust tubes.
Old Apr 12, 2010 | 04:58 AM
avner's Avatar
avner
Only one inlet is functional, the other three are dummys, but the one is plenty.
I'm sure it affects the engine performance because of the changing of sizes.
That the reason that I make the custom elbow + S pipe to keep the size 3" all the way.
Avner
Old Apr 30, 2010 | 09:17 AM
avner's Avatar
avner
You can see in those pic's how I solved the Patriot height problem
Passenger Side
Driver Side
Now I'm working on the bracket's to attach it to the frame and the brackets for the chrome net cover.
After that I want to send the elbow part to chrome plating.
Do you know/recommend on a good shop/platter for exhaust chrome plating?
Avner
Old May 15, 2010 | 04:46 AM
avner's Avatar
avner
OK, I finish now the brackets to attach the pipes to the frame.
I made two brackets for each side, and each bracket has two screws that bolt to rivet nut at the frame.
Now the pipe seat high and I don't have ground clearance problem.
Avner
To Patriot Side Pipe Height Problem.
