Bouncing speedo needle!!
Old Jan 13, 2010 | 08:28 PM
jimo's Avatar
jimo
Default Bouncing speedo needle!!
The needle on my 76 speedo bounces around alittle whilst driving, which makes it hard to determine my accurate speed.
It used to flicker abit so i took it out and cleaned her, now she bounces alittle!!
Any suggestions?
Old Jan 13, 2010 | 08:35 PM
xpoc454's Avatar
xpoc454
Mine is doing the same thing, so im interested in an answer also.
Old Jan 13, 2010 | 08:48 PM
onaqwst's Avatar
onaqwst
need more air in your tires....
Old Jan 13, 2010 | 08:57 PM
jimo's Avatar
jimo
Ha Ha
Old Jan 13, 2010 | 09:58 PM
1976 corvette's Avatar
1976 corvette
Funny to see this thread. Mine, in my 76, just went dead today on my way home from school. In my case, while I was wrenching on the car, I noticed that the insulation around the speedo wire was burned severely by one of duel pipes installed by a previous owner. Just another thing to fix but I always try look at the positives now my car won’t depreciate in value based on high miles.
Old Jan 13, 2010 | 10:06 PM
Moser28's Avatar
Moser28
My '81 bounces every now and then. I am also curious about what the cause is.
Old Jan 13, 2010 | 10:18 PM
onaqwst's Avatar
onaqwst
76 just has a cable, so maybe the cable is bad or your connection is loose....you might be able to replace the cable without pulling the dash too....
are the 80's electrical?
Old Jan 13, 2010 | 11:31 PM
sabre1981's Avatar
sabre1981
I have heard that the bouncing was somewhat normal, but don't take my word on it because the speedo on my '81 didn't when my brother bought it (I bought it from him). Onaqwst, my '81 is cable.
Old Jan 13, 2010 | 11:37 PM
Smadoo's Avatar
Smadoo
My '80 does this when driving in town, but levels out when I pick up more speed. I think I read somewhere that pouring some dry graphite powder lube in the cable might help?
Old Jan 14, 2010 | 06:45 AM
shrekviper's Avatar
shrekviper
My '69 did the same no matter what speed. The good news is it stopped...the bad news is it now only displays 0mph. I haven't had a chance to take a look at it (and now it's in storage), but I suspect a loose/broken cable. I doubt the speedo just died.
Old Jan 14, 2010 | 06:52 AM
MrJlr's Avatar
MrJlr
probably the cable
Old Jan 14, 2010 | 07:49 AM
Bo5co's Avatar
Bo5co
You can pull the cable housing then remove, clean and re-grease the cable with white lithium. Only grease the lower 2/3 of the cable (the trans end) to prevent grease from "pumping' up in to the speedo later. (Saw that part in an old GM service bulletin years ago) The cable housing wears over time and the cable starts to slop around; greasing it kind of quiets it down a bit.
Do you have cruise control? If so, two cables.
Old Jan 14, 2010 | 02:27 PM
jr105's Avatar
jr105
The speedometer on my 81 bounced a bit when I bought it. This progressed to chirping and bouncing a lot. I tried lubing it and that lasted 2-3 months before it started bouncing again. I gave up and replaced the cable and it's fine now. I would recommend that if you are going to pull the cable out to lube it just replace it. Its not expensive and it is not a job you want to do twice.
Old Jan 14, 2010 | 04:47 PM
earthquake68's Avatar
earthquake68
This is actually very common on older cars.
Remove the instrument cluster
With the speedometer disconnected from the cable, you can grab the inner cable and remove from the sleeve. (the sleeve will stay in the car and hooked up to the transmission)
Use solvent to completely clean the cable
Use the heavier lithium grease (black in color) from a grease gun tube
Slather it up so the cable is covered at least as high as the firewall. (where the tightest bend in the cable is)
Re-insert the cable into the sleeve and re-assemble the dash.
I've done this many times on anything from a Corvette to Chevelles, to Ford pick ups. It'll be good for a year. If it doesn't stay quiet for two winters in a row, think about about replacing the cable.
Old Jan 14, 2010 | 10:33 PM
pleasants9's Avatar
pleasants9
mine bounces whenever i get on the highway, just sits there maxed out at 80 mph wishing it could travel farther to show how fast the car is really going on the interstate
Old Jan 14, 2010 | 11:21 PM
81pilot's Avatar
81pilot
What a beautiful car you have there!
Old Jan 14, 2010 | 11:43 PM
jimo's Avatar
jimo
Thanks for the info.
To Bouncing speedo needle!!
Old Jan 14, 2010 | 11:44 PM
jimo's Avatar
jimo
Thanks, i will check it out.
Old Jan 15, 2010 | 12:09 AM
FlyViper's Avatar
FlyViper
Is the bounce really that bad? Mine bounces a little at lower speeds, but settles out decently above 25-30 mph.
Old Jan 15, 2010 | 05:09 AM
shrekviper's Avatar
shrekviper
Mine would bounce +/- 5 mph around 65mph. The actual speed would vary w/in the fluctuation (verified by a gps). Then, it just quite. Has anyone else had this much?
