poeder coating valve covers
Old Jan 16, 2010 | 06:33 PM
sweeet76's Avatar
sweeet76
Default powder coating valve covers
Does anyone know a ballpark price to have a set of valve covers powder coated in chrome. I just wanted to get a idea of cost before taking them to local painter to get an estimate.
Thanks,
Bill
Old Jan 16, 2010 | 06:43 PM
mrvette's Avatar
mrvette
I had my stamped steel center bolt covers....like maybe off a pickup/etc...not cast aluminum....done in black crinkle for some 40 bux....
Old Jan 16, 2010 | 06:46 PM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
I had mine done as they were painted over - had them blasted and coated, ran me $70.
BEFORE
AFTER
As "Pauldana" said - it's powder coated not chromed.
After checking the "1969 Stingray Guidebook" - it shows that 300 hp SB had stamped steel covers painted Chevy Orange and 350hp SB had finned cast aluminum. Mine's a 350hp so the coating was close as they didn't look too good after blasting. BB's had chrome.
Old Jan 16, 2010 | 06:49 PM
Flying Low's Avatar
Flying Low
New parts will be $75-$100, used parts that need extra cleaning/prep slightly more. depends alot on the shop.
Old Jan 16, 2010 | 07:19 PM
pauldana's Avatar
pauldana
now... I could be wrong, but I do not believe you can power coat on chrome. chrome has to be done by electroplating. Two completely different jobs, so, do you want to powder coat? or chrome?
Old Jan 16, 2010 | 08:40 PM
7T1vette's Avatar
7T1vette
There are "chrome-looking" powder coat paints. They look more like polished aluminum than actual chrome...but they're not too bad and a lot less money than real chrome plating.
Old Jan 16, 2010 | 09:25 PM
pauldana's Avatar
pauldana
Yea, you can see in jw3101's post.... doesn't look chrome at all... like you say, more like a semi polished aluminum.. But it is a very clean look and to be honest i like it better than chrome, not a big chrome guy myself, I like more of the aluminum look... more modern look possibly?
ok... adding this.... on chrome bumper vets, I think maybe chrome would be better there... better match, I have a 79... so no chrome...
Old Jan 16, 2010 | 10:24 PM
dmeesq's Avatar
dmeesq
I think I paid about 125 for the 2 valve covers and the air cleaner
Old Jan 16, 2010 | 10:54 PM
pauldana's Avatar
pauldana
Nice
ok, then.... here's mine... red and black crinkle, shaved aluminum fins..
Old Jan 16, 2010 | 10:57 PM
sweeet76's Avatar
sweeet76
Sorry about the mis information. My valve covers are actually aluminum but are showing signs of heat discoloration. I actually want to have them refinished with the aluminum powder coating. Thanks to everyone for taking time to reply.
Old Jan 17, 2010 | 11:08 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
pauldana, Not sure I understand your statement, chrome can be powder coated. If you want to change to a base color than blast the chrome and go with a base powder. There are powders that are meant to be sprayed over chrome, they're called translucent powders and when done right look something like an anodized part with a very deep glossy color.
I've done a few chrome parts with our home setup and they have a very nice finish.
I'm no powder coating expert
Most of my info come form the company's that produce the powders
Neal
Old Jan 17, 2010 | 11:41 AM
pauldana's Avatar
pauldana
Neal
misunderstanding of my statement,,, yes, you can put a powder coating ON chrome, but you can not do a powder coating OF chrome. :***** :
Old Jan 17, 2010 | 12:38 PM
Vette Rookie's Avatar
Vette Rookie
Here is a pic of a master cylinder that I coated at home with "Eastwoods" chrome powder, I did not "smooth" the casting prior to coating and did not apply the clear which they recommend as a sealer - should have, since the brake fluid does react with the finish.
Old Jan 17, 2010 | 01:17 PM
pauldana's Avatar
pauldana
nice, i like that but it still looks more like semi polished aluminum, but again, that is what I like... where do you get that? and $$??
Old Jan 17, 2010 | 02:08 PM
Vette Rookie
I got the powder from Eastwood, 8oz for $15, and only used about two tablespoons:
http://www.eastwood.com/hotcoat-powd...ve-chrome.html
I used a Craftsman gun which runs about $100 and does not require a compressor like a lot of the other systems out there. It does have a small powder contianer, so it does limit the amount of powder you can dispense.
Old Jan 17, 2010 | 02:23 PM
pauldana's Avatar
pauldana
how and where do you cook it? what do you use for an oven? is there any electrolysis (sp?) involved?
Ok...edit.... went to the web site, states 400 degrees, I wonder if that would melt things like plastic lens's? if not that would be cool...
Here are 3 reviews of the product from that web site:
"Great looking product.It is very simple to apply ,and good coverage. I am going to do alot of engine parts with this, Thanks"
"I did a brand new SBF allum intake manifold. It looked great for a few weeks till I changed jets and the fuel melted the powder coat and turned it into a mess. This coating is not as resilient as they say. I stripped it all off after 1 year using Permatex gasket remover. Came very clean with to coats, no sanding needed at all. I'm going back to base coat clear coat automotive base paints as they hold up better and look really nice."
this goes on nice and looks awesome when cured, but fades in sunlight after a short period time(6months). Works great for interior parts"
VR, did you bake your MC? and does it react to brake fluid just like regular paint?
thx
Old Jan 17, 2010 | 02:54 PM
Vette Rookie
I use a standard kitchen oven that I have in my shop (I use an extra unit as it makes the food taste funny) at 400 - 425 degrees depending on each powder. The gun has a negative clip that you attach to the part so you get the negative charge to attract the powder to the surface. The brake fluid has caused the MC to discolor. The powder recommends using a clear coat to seal but I did not use it (should have and will have to try in the future).
To poeder coating valve covers
