Tail Lights Issue 68
Old Jan 19, 2010 | 04:25 PM
68whiteshark's Avatar
68whiteshark
3rd Gear
Default Tail Lights Issue 68
My tail lights come on, however the brake lights do not work when I press the brake.
Does anyone have any idea on what the fix is????
Help needed, as I cant drive it until I can fix this... and it's starting to warm up a bit in Dallas.!!!!
Old Jan 19, 2010 | 05:03 PM
RobRace10's Avatar
RobRace10
My first thought would be the fuse. On my 69 it is the second fuse up on the right hand row, just above the short fuse. It looks like that fuse also connects the hazard flashers, do they work?
The tail lights are on a totally separate circuit than the brake lights. Otherwise the brake switch or wires on the brake pedal assembly.
Old Jan 19, 2010 | 08:38 PM
Ironcross's Avatar
Ironcross
or the stop lite switch,.........
Old Jan 19, 2010 | 09:43 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Yup.
Old Jan 19, 2010 | 10:01 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Do your blinkers work? It could be in the steering column assembly.
Old Jan 20, 2010 | 04:06 AM
7T1vette's Avatar
7T1vette
The brake light switch mounts on the brake pedal arm under the driver's dash. You can use a voltmeter to see if you are getting 12vdc out of the switch when the pedal is depressed. The switch could be bad, the switch may have come loose and need to be repositioned, or you may have some other electrical problem with the brake signal wiring. The switch is the most likely problem.
Old Jan 20, 2010 | 08:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stop light switch might be good and only need to be pushed a little closer to the brake pedal arm.
Old Jan 20, 2010 | 12:42 PM
68whiteshark
3rd Gear
Thank you to all of you for your responses... I will begin further investigation on this issue.
Thanks!
Eric
1968 427
Old Jan 20, 2010 | 02:13 PM
DZRick's Avatar
DZRick
This is the '68 only brake switch, you can see the two slotted holes used to mount and position the switch.
Old Jan 21, 2010 | 02:00 PM
RHD '68 L89's Avatar
RHD '68 L89
The brake light signal goes through the turn indicator switch in the column. IF you are NOT turning, the signal goes to both sides, if you are turning it goes to the side opposite the turn. Do your indicators work? Check the Harmonica connector into the column. Check the fuses as well.
Old Jan 24, 2010 | 08:05 PM
68whiteshark
3rd Gear
Default Replacing Bad Brake Switch
Okay... so now that I think the problem with the brake lights is the switch... How might one replace it without taking the dash out...
68whiteshark
Eric
Old Jan 24, 2010 | 09:07 PM
PRNDL's Avatar
PRNDL
If you are a contortionist you can reach up under the dash and replace the brakelight switch. I couldn't do it. I have read round these parts that it helps to remove the drivers seat. You still need to be a contortionist. All this assumes that you have a replacement for your 68 only corvette only 1 year only braklight switch. Alternatively, you can get a standard $7.99 brakelight switch and with a little help from bubba you will have working brake lights.
Old Jan 24, 2010 | 11:04 PM
DZRick's Avatar
DZRick
I was able to replace mine and I wasn't smart enough to think of removing the seat. It was definitely a PITA!
If I remember correctly there are two studs mounted on the pedal assembly that the switch mounts to but it will be obvious whether I'm right or not once you get started.
The brake switch was without a doubt an improvement in the '69 model.
Old Jan 24, 2010 | 11:53 PM
1969RAY's Avatar
1969RAY
Be sure it's not just adjustment. If it is the switch-do what ever you have to do.
Old Jan 25, 2010 | 10:51 AM
7T1vette's Avatar
7T1vette
Remove the driver's seat to work under the driver's-side dash. Four bolts and it's out.
To Tail Lights Issue 68
