birdcage rust worrywarts
Old Jan 21, 2010 | 11:53 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default birdcage rust worrywarts
have you ever seen a windshield break or collapse because of rust?
have you ever seen a door fall off?
Old Jan 22, 2010 | 12:03 AM
eastltd's Avatar
eastltd
Do you think the girl in your avatar is safe sitting on that door?
Old Jan 22, 2010 | 12:54 AM
vettebuyer6369's Avatar
vettebuyer6369
Actually, back in the 70's when the windshield in my '68 just cracked from the top for no apparent reason, the shop replacing the W/S called me over to show me the rust holes in the W/S frame, near the crack. It was their opinion the W/S crack was because of the rusted weakened WS frame.
That said, I totally agree that people get way too crazed over the birdcage rust issue. Ive been through dozens of these cars over the years, and the fact is windshield frame rust is common. Period. It doesnt mean the car is bad. Ive had them fixed.
Im waaaaaay more interested in the side rail/kickup rust issues. Way more important.
Old Jan 22, 2010 | 01:08 AM
hwcoop's Avatar
hwcoop
My doors were rubbing the quarter panels the kickups were so bad and my rocker channels were crusty enough it was bulging the fiberglass in the sills. All better now after
Old Jan 22, 2010 | 06:46 AM
Roco71's Avatar
Roco71
My best friends 69 broke in two from the frame being rusted.
Old Jan 22, 2010 | 07:42 AM
joewill's Avatar
joewill
perhaps it is overblown, but in reality, knowledgeable buyers will not buy cars with rusty windshield frames and sellers have to drop the price drastically.
Old Jan 22, 2010 | 09:01 AM
mrvette's Avatar
mrvette
P/Owners had properly painted the entire car, so RUST per se was not an issue when I bought my car...the inside padding/headers were gone and rusted out support ribbing, so that was replaced....while I had it all down, I pulled that stainless trim, having seen leaking over the top bow/gasket, and having had experience with other convertibles over some years, I pulled all the trim, and flooded the entire w/s channel area with RTV black from caulking gun size tubes, rebedded the trim, and wrapped black vinyl over top of the stainless..from under the trim up and over to below the new header....that whole thing is buried in RTV now, totally water PROOF, been that way for years....being as it's a '72, the fenders are much closer to the glass, so I filled all the gaps from lower trim stainless/fender area down to inside with RTV also....rust out/leak NOW, bitch...
Old Jan 22, 2010 | 10:18 AM
longbros's Avatar
longbros
I have one in my garage right now that is so bad, that when you close the door with the window rolled up, the windshield frame will clearly move or flex forward when the door glass contacts it.
Old Jan 22, 2010 | 10:29 AM
wcsinx's Avatar
wcsinx
Yes
I watched the windshield frame fall off an old jeep because of rust. The owner was puttering in reverse, hit the brakes, and there was a *crunch* as the windshield & frame fell backwards. It missed his head by inches. The glass hit the top of the steering wheel, broke, and smashed his hand up pretty bad in the process.
So yeah, I'm comfortable being a rust worry wart.
Anymore stupid questions?
Old Jan 22, 2010 | 10:35 AM
longbros's Avatar
longbros
It is what you can't see that will get you!
Old Jan 22, 2010 | 11:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...have you ever seen a windshield break or collapse because of rust?...have you ever seen a door fall off?
What's your point?
Old Jan 22, 2010 | 11:23 AM
wcsinx's Avatar
wcsinx
What's your point?
He's trying to justify not repairing his rusty old car.
Old Jan 22, 2010 | 11:32 AM
turtlevette
Originally Posted by wcsinx
Yes
a Jeep would be more comparable to a convertible C3 Nothing else to support it but the windshield frame. I would be more concerned on a vert that didn't have the T bar stabilizing the whole frame.
But i didn't ask about a Jeep. I was wanting to know of anyone has seen a catastrophic windshield or door failure on a C3 due to birdcage rust.
I understand that you have to be careful purchasing a C3. No argument there. But for someone who has a car of sentimental value the tolerable limits will be greater. Do you junk a car you've spent 30 -40 years with or keep on moving while closely monitoring things all the while. Mine has a lot of rust. I've vacuumed a lot of rust over the years. But it's still solid in my opinion. If i spray rust preventative on, i may get another 20 years out of it and that's all i need.
Old Jan 22, 2010 | 11:56 AM
joewill's Avatar
joewill
turtle, that is ok, but in 20 years your car may be worthless.. of course alot of people prefer to die with a zero networth!
Old Jan 22, 2010 | 12:02 PM
halfmoontrail's Avatar
halfmoontrail
I have found that the rust converters (Rust Fix, the old Extend) work great, much better than "rust preventive" coatings
Old Jan 22, 2010 | 12:39 PM
wcsinx's Avatar
wcsinx
Wrong
No qualification as to specific vehicle was made. Thus I may infer that you are asking about all vehicles.
So yes, you did ask about a jeep.
Define catastrophic. I've seen pictures posted here as late as this very week showing swiss cheese metal all around the windshield. Lean on something like that the wrong way, and it very well could be "catastrophic".
I mean you're asking how bad does it have to be before it falls apart all on its own. That's basically what your line of questioning boils down to isn't it?
Old Jan 22, 2010 | 02:54 PM
turtlevette
Did you test the swiss cheese to see how big a load it will take? You might be surprised. A car that has some rust holes in the bird cage is not necessarily ready for the scrap heap.
I asked if anyone has ever seen a C3 failure in the windshield or door and nobody so for has. That says something.
To birdcage rust worrywarts
Old Jan 22, 2010 | 03:01 PM
wills670's Avatar
wills670
I don't know what you define as a failure but I have seen a whole lot of c3's with busted windshields with no apparent cause and then look it over a find a severly rotted windshield frame.
There has even been a few post here where guy's had windshields replaced and then had another broken glass right after the replacement only to find severe rust and then figured out flexing was causing the broken glass.
Old Jan 22, 2010 | 03:03 PM
pewter-FRC's Avatar
pewter-FRC
i had a 73 vert parts car that when you opened the doors and lifted up on the drivers side the dash and steer column moved up and down a few inches
Old Jan 22, 2010 | 03:42 PM
Vampyre's Avatar
Vampyre
^ That was just an early version of the tilt wheel...
