birdcage rust worrywarts
I asked if anyone has ever seen a C3 failure in the windshield or door and nobody so for has. That says something.
I asked you to define a catastrophic failure, and you did not. Multiple people have now related stories of inexplicable windshield breakage due to a rust compromised frame. That sounds pretty catastrophic to me. What more would you like to know?
1. What is a fair, simple test of the structural rigidity of the windshield frame and door mounting? My feeling is that if the corner of the windshield can withstand 100 pounds force in each direction it's structurally sound. If an open door can support 100 pounds without failure that's a fair test in my opinion.
2. How to easily treat the rust without tearing the interior completely apart. I've had the interior trim around the windshield off for years and there are definitely cracks and holes by which a small tube could be inserted to apply some spray product.
3. What kind of products to use. Most of the rust will not be reachable with a paint brush so i'm thinking it needs to be a spray product. I've applied Vasoline to the body mount areas around 7 years ago and that's actually looking like it is stopping further rusting in that area.
4. When the windshield is replaced it should be replaced with the thicker one rather than the thinner one. I've always heard the 80s models had a thin windshield to save weight.
Just sayin'
Kelley
My dad (an old naval mech/hydraulic engineer) used to throw around terms like "5x standard". Which is to say if you're going to support something that weighs X, then you need to build the support strong enough for 5x+. E.g. you want to hoist a 200 lbs load, you use a rope tested for 1000 lbs or more. It's just a heuristic, but it's a good one.
Take a 5 lbs hand weight and drop it on a scale from 6 feet up. How far did that needle swing? Quite a bit more than 5 lbs, right?
Are you kidding me? I could have every interior piece including the carpet yanked out of my C3 in under an hour. screws and clips ... that's it.
