Door closing issues...
Old Jan 22, 2010 | 08:58 PM
The13Bats's Avatar
The13Bats
Default Door closing issues...
I have seen this on many c3's the door closes and latches part way, you have to really close it hard to get it to close all the way,
In my case the handle is wicked hard to squeeze to open the door,
So what should I start looking at to fix this on the drivers side as my passenger door is perfect,
Old Jan 22, 2010 | 09:14 PM
mds3013's Avatar
mds3013
Same on mine. I think the driver side door hinge bushing is worn but there is no obvious sign of this in door height at rear of door. Also my door striker had the rubber cushion come out from under the rotating band. Adjusting striker helped some but drivers side is not as smooth as pass. side. mds...
Old Jan 22, 2010 | 09:24 PM
The13Bats's Avatar
The13Bats
Right...my door doesnt "appear" to be sagging but who knows,
I have never ran into a c3 that the handle was so hard to squeeze though...
Old Jan 22, 2010 | 09:29 PM
MakoShark72's Avatar
MakoShark72
Bats,
Having just hung the doors on my 72, if the large metal post that the latch "latches to" on the rear door jamb is not adjusted correctly up/down, it can be a b#tch to actuate the door handle. Out of adjustment it can put the door latch in a bind situation. Also, that post adjustment "inboard and outboard" will determine how far your door closes...
You probably knew all that!
Rob
Oh yea, as above...the striker!
Old Jan 22, 2010 | 09:33 PM
mds3013's Avatar
mds3013
The handle on mine is ok but latch and striker are hanging a bit. Also bottom of door panel rubs against rubber/aluminum piece at back of door sill. mds...
Old Jan 22, 2010 | 10:00 PM
The13Bats's Avatar
The13Bats
Originally Posted by MakoShark72
Bats,
Rob
Naw...I didnt "really" know any of that, just the very basic idea, I will much around with the striker post, but that handle is hard as hell to mash even with the door open
I started to wonder perhaps some linkage is bent in there or something,
alos when the handle is at rest rather than sag a little it actually looks a hair too high
Old Jan 23, 2010 | 08:01 AM
bobbarry's Avatar
bobbarry
I've got this problem with my passenger-side door.
I get the feeling the linkage in the door is freezing/sticking, and the binding in the linkage is holding the latch open just a tiny bit, not letting the latch close all the way all the time very easily.
Old Jan 23, 2010 | 09:41 AM
mrvette's Avatar
mrvette
Batty, them door handles are a bitch to work on and very EXPENSIVE for a good one, stay away from the import China junk....hard to do....
they can break really easy, there is a metal cast piece on the bottom there, connected to a lever....you need pull the door latch outta there and clean/lube make sure it works really easy....then get that handle outta there before the disaster happens, you maybe see a loose rivit on the pivit....so tap it home again....carefully....this is hard to do, but get some wheel bearing grease under the handle flapper on top there, to assist it's operation on the mechanism....less stress on the casting...
you need a 1/4 inch universal on a short socket to your handle for the bolts holding that handle assy to the door.....
Old Jan 23, 2010 | 09:43 AM
markids77's Avatar
markids77
Assessing the problem here will require you remove the door panel and the sound deadener if it's still there. Get a strong flashlight and have someone work the door handle while you look for rust/gunk/slop in the rods and latch mechanism. Chances are good the cause will show readily. DO NOT simply hose the interior of your door with a penetrating lubricant in an effort to loosen things up... it can bleed through from the inside making life suck later. Remove the offending bits from the door for cleaning or repair.
Old Jan 23, 2010 | 06:02 PM
71406's Avatar
71406
had a similar problem with the passenger side outside handle. Very hard to work. Took it out and lubed the lever as mrvette stated above and also lubed the pin that the handle pivots on. I recommend taking out the latch first for easier access to the nuts holding down the handle.
Old Jun 8, 2022 | 11:41 AM
Donws's Avatar
Donws
Is it that you have to slam the door hard for the locking gear to close on the striker which would be why the door latch is so hard to release from the striker? I changed out the hinge pin on my door last night and now I’m facing the same issue. If the door striker is move out to relieve the pressure my door doesn’t line up with the back body. Is this your issue as well.
Old Jun 8, 2022 | 12:44 PM
kodpkd's Avatar
kodpkd
12 year old thread. I hope they fixed it by now.
Old Jun 8, 2022 | 04:43 PM
Donws's Avatar
Donws
Wow, not sure how I even joined this thread, 12 years 😳
Old Jun 9, 2022 | 03:17 PM
derekderek's Avatar
derekderek
you researched a door issue. and sdidn't realize it was necro...
To Door closing issues...
