issue decoding vin
Old Jan 25, 2010 | 07:31 PM
drifter99's Avatar
drifter99
2nd Gear
Default issue decoding vin
im working on a 1979 corvette and when i was trying to find the vin number to see what the options the car came with from factory , i ran into the simple issue that the car doesnt have any were the 1979 shop manual says they should be.... i have looked high and low from door jams to dashboards and fire walls and havent found a thing, the only thing i found was a california issued idetification number on the inner door jam on the drivers side.... its a 9 digit number and is the only thing i see that remotelly close to any sort of identification number.. its also has a widebody kit on it , which look some what like the
can-am cars, if that makes a difference... not a hundred percent sure what to do at this point , so any help will be huge.. thanks in advanced
Old Jan 25, 2010 | 07:35 PM
gjohnson's Avatar
gjohnson
Sounds like it might have a salvage title.
Old Jan 25, 2010 | 07:40 PM
Mike Ward's Avatar
Mike Ward
Even if you found the VIN it wouldn't tell you which options came with the car, other than engine type.
Old Jan 25, 2010 | 08:05 PM
joewill's Avatar
joewill
your vin will be on your title...
Old Jan 25, 2010 | 10:31 PM
Jclgodale3's Avatar
Jclgodale3
Old Jan 26, 2010 | 12:54 AM
drifter99's Avatar
drifter99
2nd Gear
im helping a friend restore it and the registration has the same number were the vin should be on it.....
Old Jan 26, 2010 | 01:59 AM
vettebuyer6369's Avatar
vettebuyer6369
You likely have a "remanufactured" or "reassembled" VIN. It could be a salvage title, but I know my late model convertible conversion had a VIN plate attached to the LH door jamb, and I was told by the Michigan DMV that a car with major changes (I dunno, like cutting off the roof) required the remanufactured number in that state.
Hearing that the car you are looking at has a Can Am kit, likely with major body modifications, it sounds like the same deal.
NOTE: the original VIN should still be in the stock place on the LH inner windshield post, readable through the windshield.
Old Jan 26, 2010 | 10:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
To issue decoding vin
