Windshield Glass install
Old Jan 28, 2010 | 09:20 AM
Hornevette76's Avatar
Hornevette76
Default Windshield Glass install
Iam getting ready to give my 76 a new paint job, my windshield has a small blemish on the bottom of the drivers side, so I wanted to replace before painting. Stopped by the glass shop, they said they would do the job if the frame was not rusted. The guy said he had done many of these on vette's and have not found many that didn't need a lot of work on the frame before the glass. I was just wondering if there is a way to check mine out before I let him do the job. He seemed very knowlegeable about this in vette's. Any help would be great.
Thanks in advance
Old Jan 28, 2010 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I am assuming you are removing the windshield moldings in prep for paint. You can check the condition of the W/S frame at that time. You can also remove the interior trim panels and check the condition on the inside of the car.
Just the same, once the old windshield is out and the channel cleaned up, some spots of rot might show up.
Old Jan 28, 2010 | 05:24 PM
Hornevette76
Thanks Mike for the reply, Iam checking with the boby shop to make sure they can do the welding on window channel, if it needs it, I guess it will. The glass guy said he would go the his shop and install the windsheild, that sounds like a plan to me. Iam new to this vette stuff so just bare with me if I ask some stupid ?'s. Been reading every day on the forum, it sure has some great info, from some real knowledgeable guys.
Old Jan 28, 2010 | 09:32 PM
zwede's Avatar
zwede
Double check that the glass guy will use a ribbon seal and not polyurethane from a caulking gun. Many glass shops insist on the polyurethane but it will set the glass too far in and the moldings won't fit.
And yes, odds are good that the windshield frame will need at least some repairs.
Also, I don't see any need to move the car to another shop just to install a wind shield. It's quite easy and takes less than 30 minutes.
Old Jan 29, 2010 | 08:53 AM
Hornevette76
Thanks for the info on the ribbon seal, I'll make sure on that one, sure don't want any problems with the windsheild trim not fitting.
No, the car is not going to another shop for the install, glass guy said he would come to the body shop and do it.
Thanks again
Old Jul 16, 2010 | 03:34 PM
jdizon's Avatar
jdizon
4th Gear
Many glass shops insist on the polyurethane but it will set the glass too far in and the moldings won't fit. . You don't need to wait weeks for auto glass guy to come to Chandler for your car.
Old Jul 16, 2010 | 04:11 PM
Timsride's Avatar
Timsride
When I did my vert I had to replace the top header part then grind any surface rust out of bottom edge. I then used etching primer where the sealer was going to be placed. and waited a week for the primer to fully cure. If Your going to do it get it as good as You can. You don,t want to have to do it again. Good luck.
Old Jul 16, 2010 | 06:55 PM
jimo's Avatar
jimo
I replaced the windshild in my 76 a few months ago, did it in a mates shop so we were able to take everything off and then got the glass guy to come in and take it out, my mate then did some work on the frame, i was lucky as it wasnt to bad!! and once it was finished we called the glass guy to come back and install it, i can finally see through the windshield
To Windshield Glass install
