1971 Corvette Front Side Marker Lights
Old Jan 29, 2010 | 11:45 PM
71corvette's Avatar
71corvette
Default 1971 Corvette Front Side Marker Lights
I was looking at my side marker light before reinstalling it and I noticed a bunch of silcone sealer on it. Further investigation shows that someone has removed the plastic lens at some point. So, I popped out the lens and I found this aluminum reflector inside of the lens. But somehow it doesn't seem right to me. The inside of the housing is chromed so why would there have to be an additional reflector?
Is this some sort of add-on or aftermarket piece that someone installed? The lens seems to fit a lot nicer without the aluminum piece.
Anyone ever heard of this?
Old Jan 30, 2010 | 09:23 AM
70Yellowbird's Avatar
70Yellowbird
When I bought an extra OEM set some time ago, one assembly had a loose lens ... so I took it apart and found the reflector that you are describing.
So I think the reflector is OEM. Why is it there? I'm guessing it may have something to do with the rectangular hole in the middle ... but not sure.
Hope this helps.
Old Jan 30, 2010 | 09:52 AM
Alan 71's Avatar
Alan 71
Hi 71c,
I agree with 70y that the reflector is there and that the lens was held in place with the 1971 version of a bead of clear silicone sealer.
Regards,
Alan
Old Jan 30, 2010 | 11:46 AM
71corvette's Avatar
71corvette
Ok, thanks for the information. I was about ready to silicone the lens back in without the reflector but I will put it back in.
Thanks for your help.
To 1971 Corvette Front Side Marker Lights
