Carpet plugs
Old Jan 31, 2010 | 11:08 PM
jordan89's Avatar
jordan89
Default Carpet plugs
I am about to install the carpet on my vette and have a quick question, are the carpet installation plugs really necessary? I don't have them and would have to order them, and that's why I ask.
Old Jan 31, 2010 | 11:22 PM
682XLR8's Avatar
682XLR8
I had a hell of a time installing them, so I just left them out
Old Jan 31, 2010 | 11:29 PM
jordan89's Avatar
jordan89
I don't even know where they are suppose to go, so I would imagine if I were to do this it would be a PITA trying to figure out.
Old Jan 31, 2010 | 11:59 PM
mydejavooo's Avatar
mydejavooo
Carpet plugs??? What the heck is a carpet plug?
Old Feb 1, 2010 | 12:06 AM
682XLR8's Avatar
682XLR8
If you have a factory assembly manual it should show where they go. There's holes(about 3/8 dia IIRC) in the firewall where the plugs go. But if you're not doing a correct resto, I wouldn't even worry about it
Old Feb 1, 2010 | 12:55 AM
72ls5fla's Avatar
72ls5fla
if you don't want to use them, be sure to plug all the holes up before laying the carpeting down.
You will get heat leaking in and possibly water while driving.
If you do a good job gluing the carpet in, I think you can skip the plugs.
My 2 cents...
Old Feb 1, 2010 | 02:23 AM
7T1vette's Avatar
7T1vette
Well, it would have been cheaper and easier for the factory to have used glue...but that wouldn't hold the carpet on vertical surfaces for long. Carpet plugs are easy to install. Use a large needle to push through the carpet to find the holes for the plugs...then mark them with chalk. Use a carpet knife to cut a small "X" at the chalk marks. Slip a carpet plug over the end of a small Phillips screwdriver and push the plug through till it seats well. Be careful not to push too hard or too far, or the screwdriver will go right through the plug. You can put a little wipe of grease on the outside of the plug to make it slip in easier, if you want. There are 9 plugs, if I remember correctly: 3 on back wall of storage compartment and 3 on each side of the front carpet going up the firewall.
Old Feb 1, 2010 | 08:03 AM
gr8t73's Avatar
gr8t73
I punched through three of the inserts while using a phillips screwdriver finally smarted up and ground off the end of the screwdriver. I rounded off the end so there were no sharp edges and yes a dab of grease or silicone lubricant helps a lot.
Old Feb 1, 2010 | 10:09 AM
70Yellowbird's Avatar
70Yellowbird
Here's a pic of a carpet plug installation tool offered by a vendor. I would not bother purchasing one because it looks so simple to make.
It appears that the shank is just long enough to slightly elongate the plug ... but not too long to go through the plug tip.
Old Feb 1, 2010 | 11:49 AM
jordan89's Avatar
jordan89
I'm gonna see if I can find where those plugs go. I have something that looks like that tool that the vendors sell, so I'll just use what I have. I'm also gonna see if the new carpet has the holes for the plugs.
Old Feb 1, 2010 | 09:28 PM
7T1vette's Avatar
7T1vette
The carpeting will not have the holes pre-cut. You will have to find and mark the hole locations.
Old Feb 1, 2010 | 09:32 PM
jordan89's Avatar
jordan89
OK. I think I'm just gonna cover the holes.
To Carpet plugs
