Bubba's $5 blasting cabinet
Old Feb 1, 2010 | 10:26 PM
MyRed69's Avatar
MyRed69
Default Bubba's $5 blasting cabinet
Here are a couple of pix of my $5 blasting cabinet. I was doing the thrift store cruise for a powder coating oven (found one, $10 and a convection oven twice the size of a toaster oven $8[removed the fan])... Anyway saw an old stereo cabinet in the corner and thought, hmmmmmm, if i put it on its back and cut a couple of holes in it for arms, shop vac, air, etc, It works great, glass is starting to get a little cloudy but should make it to the "end" of the restoration.
Old Feb 1, 2010 | 10:31 PM
onaqwst's Avatar
onaqwst
curious if the glass is tempered and if it will explode if enough material is removed from it.... tensioning/etc.... hmmm
Old Feb 1, 2010 | 10:40 PM
MyRed69's Avatar
MyRed69
99% sure it's tempered, had a similar one years ago and broke one of the doors into a zillion little pieces. Only have a few parts left to do so i don't think i'll be removing all that much material from the glass, barely noticeable now after an entire weekend of blasting. Still wear the safety gear too.
Old Feb 2, 2010 | 03:44 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I like it. Recycling at its best.
Where's your media hopper: inside or outside the box? Is the dust control ok? (I keep telling myself to wear the mask -> every <- time I start squirting aluminum oxide: i'm getting better.)
How about a light? Didn't see one but may just be the angle.
Old Feb 2, 2010 | 07:07 PM
MyRed69's Avatar
MyRed69
No hopper, I have one of those northern tool gravity feed guns. It's kind of a pain but helps me keep from abusing the duty cycle of my compressor. I mostly use it outside and use the sun for light, plenty of visibility. the shop vac connection works pretty well for the dust inside the cabinet but i still wear a mask and glasses.
Old Feb 3, 2010 | 02:15 AM
rexx78's Avatar
rexx78
Neat idea!
How do you get your hands in there when the door is closed?
Old Feb 3, 2010 | 07:53 PM
MyRed69's Avatar
MyRed69
Originally Posted by rexx78
Neat idea!
Those white circles are actually cutouts with 'sleeves' that have elastic on the ends. I got a couple from the fiberglass store to keep the fiberglass dust off my arms while sanding an earlier project. I cut one in half and taped the open end to the box. I just slide my hands in with some gloves and it keep the dust inside the box to get sucked out by the shop vac.
Old Feb 6, 2010 | 12:06 PM
Rockn-Roll's Avatar
Rockn-Roll
Good job...should work for most of the parts. I sprung for the blasting cabinet from Harbor Freight...saved me a lot of money. I had already spent over $400 taking parts to a shop for sand blasting and now that I'm doing my own I realize how poorly a job they had been doing. A blasting cabinet pays for itself when doing a restoration.
Old Feb 6, 2010 | 04:44 PM
demonx's Avatar
demonx
What I do with my cabinet is use masking tape to hold overheard projector sheets to the inside of the window.
When it gets so bad I cannot see through it I just peel it back and put a new one one and then theres 100% visability again.
I do the same thing with a faceshield when I'm using my portable blaster.
Works a treat and its extremely cheap.
A also wear the same mask I wear when I'm painting as the dust doesnt feel too good in your chest!
As mentioned before - these things pay for themselves so quickly and when you pay for it to be done they dont care about the quality. VERY good investment when restoring a car.
Old Feb 12, 2010 | 11:39 AM
MyRed69's Avatar
MyRed69
Sooo true, I HATE having to send work out...
To Bubba's $5 blasting cabinet
