Need help with date coding / build dates.
Old Feb 2, 2010 | 07:07 AM
L Holmes's Avatar
L Holmes
Default Need help with date coding / build dates.
Picked up a rough "project car" a few weeks ago. Its a 1970 coupe. Appears to be a 350 350 hp car but Im leary about the originality of the motor. The car was built in late April but the date codes on all the motor parts, block, heads, etc. is January 1970.
Is it pheasable that a motor built in Jan. 1970 wouldnt find its way into a car until late April 1970? If not whats about the greatest time difference between a motor build date and car build date you should accept when looking at these cars?
thanks
Old Feb 2, 2010 | 08:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by L Holmes
...Is it pheasable that a motor built in Jan. 1970 wouldnt find its way into a car until late April 1970?...
Usually not.
...If not whats about the greatest time difference between a motor build date and car build date you should accept when looking at these cars?...
The NCRS will allow up to six months between engine assembly date and vehicle time/build date. In most cases, the actual time frame is much shorter -- usually no more than a couple of weeks. The engine in my '68 was assembled on April 9, 1968. The time/build date on the car is April 20.
Check the pad on the block at the front of the right head. You will find two numbers stamped there. One will be the engine code and will identify when and where the engine was assembled and it's suffix code. The second stamp will be a derivitive of the VIN of the vehicle the engine was originally installed in.
Old Feb 2, 2010 | 04:30 PM
Alan 71's Avatar
Alan 71
Hi LH,
I'll agree with Mike. That amount of time while not the norm would be feasible.
I believe 70 production didn't begin until January, so I guess there could be some oddities.
Regards,
Alan
Old Feb 2, 2010 | 05:34 PM
L Holmes's Avatar
L Holmes
Thanks for the info. guys.
Old Feb 2, 2010 | 08:42 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
1970 was an odd year with a big strike. If there are any years in the C3 that will have skips in dates from production to assembly, it will be this one.
Old Feb 2, 2010 | 08:46 PM
Mike Ward's Avatar
Mike Ward
There's lots of weird and wonderful date combinations out there. A January engine in an April car wouldn't get me worried. Got a photo of the stamp pad?
To Need help with date coding / build dates.
