'69 Corvette Convertable Price
Old Feb 4, 2010 | 11:39 AM
Jazzcorvette's Avatar
Jazzcorvette
2nd Gear
Default '69 Corvette Convertable Price
Im intristed in purchasing this car. The guy's add reads this and is asking $18000.
'69 Corvette 427 ( non original engine ) was a 435 HP Tri-Power car. 4-speed, new clutch. Original rearend w/ 4:11 Posi, factory sidepipes. Oringinal color was Lemans Blue. Newly recovered seats. Five correct rally wheels go with the car. 55,000 original mile car.
Also the car is now painted red. The engine is a 427 built 454. Internaly balanced, 427 rotating assembly, Hi Perf. rectangular port heads, factory LS6 manifold. acording to the seller.
I was woundering if anyone could help me determine the value of this car and questions i should ask/things to look for.
Thx for your help,
Brian
Old Feb 4, 2010 | 11:45 AM
markdtn's Avatar
markdtn
Needs photos. Could be a steal, could be way high.
Old Feb 4, 2010 | 11:57 AM
Jazzcorvette
2nd Gear
Default pictures
I cant upload them because i dont realy know how, but here is a link to a photo bucket album.
http://s962.photobucket.com/albums/a...name/corvette/
Last edited by Jazzcorvette; Feb 4, 2010 at 12:02 PM. Reason: Trying to upload pictures
Old Feb 4, 2010 | 02:32 PM
vettebuyer6369's Avatar
vettebuyer6369
Old Feb 4, 2010 | 03:44 PM
markdtn's Avatar
markdtn
You can't really tell too much from the 4 photos. Looks OK but hard to really tell. Any rust in the frame/birdcage/windshield frame/front top bow? Why 55k miles and a new engine? Why only 55k miles? How has it been stored for the last 40 years-inside/outside/covered? How is the rest of the interior besides the newly covered seats-carpet, dash, console, door panels? How is the top? How is the chrome-new/old/good/pitted? Where are the missing parts like the ignition shielding? Is the paint excellent or just 20 foot? Did they take the car apart or just mask it to paint? Why change the color? How are the brakes-recently redone or original? Does it have a tank sticker or window sticker with it? How about the original block and other engine parts-are they available? How is the suspension? Rear bearings/trailing arms? Driveline? Ever been wrecked? Do the fiberoptics work? Do the wiper door and headlight doors work by vacuum as original? Does everything electrical work? Original radio? If not, did they cut the dash? Does it have a hardtop? Is it power steering (doesn't look like it)? Tilt-n-tele or straight column? Original steering wheel and horn button? Original gauges or aftermarket-especially tach and do they work? Is that an original tach drive distributor or aftermarket or is the tach disconnected? That should get you started.
Old Feb 4, 2010 | 04:49 PM
Alan 71's Avatar
Alan 71
Hi Brian,
A 69 427 convert is a very valuable car. As soon as the original motor is gone the car loses some of it's value and it's appeal to some people.
If originality isn't of prime importance to you this might be a great car for you.
If you don't know too much about 69 cars I suggest you find someone very knowledgeable to look at the car with you and give you some guidance and a bit of education
I'd think some of the things to determine, as mdtn said... was it a big block car originally, was it a side exhaust car originally and most important... what is the rust situation?
Even though the original motor is gone it would be very good if the things that went along with the big block option are still with the car.
GOOD LUCK!
Regards,
Alan
Old Feb 4, 2010 | 09:55 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
An original or long time owner can (and probably would) tell you alot about the car's past. Where did the car spent most of its life? Western, dry states will keep rust to a minimum.
And he would probably take $15,000. If it dosent need a total redo or if you want a decent maybe not perfect '69 that's a pretty great price.
Drive it first.
Old Feb 5, 2010 | 11:32 AM
halfmoontrail's Avatar
halfmoontrail
I see the emissions/tuneup label on the cowl, if it is original it tells you two things:
1. Pretty good clue to care over the years, else it would be long gone
2. Two-letter code will tell you original engine/trans combination
Steve
To '69 Corvette Convertable Price
