Sound - headers?
Old Feb 8, 2010 | 03:48 PM
kmobrien76's Avatar
kmobrien76
Default Sound - headers?
I have a 350 engine, factory rate 195 HP, previous owner states mild cam and some head work done, he estimated at 240HP but who knows...has nice sound for close to stock...auto trans...
Thoughts, if I put headers on it will it give a nice throaty sound?
I want it to sound greeeeeat!
Kevin
Old Feb 8, 2010 | 04:06 PM
Gilded_Splinters's Avatar
Gilded_Splinters
Of course it will.
Old Feb 8, 2010 | 04:09 PM
kmobrien76's Avatar
kmobrien76
How much louder?
Got a link to cheap headers?
Are they an easy install for a shop or crazy modifications needed?
Thanks,
K.O.
Old Feb 8, 2010 | 04:26 PM
MrJlr's Avatar
MrJlr
A nice exhaughst system will help a LOT too and give you more HP....it would also help if I could spell...
Old Feb 8, 2010 | 04:30 PM
Roco71's Avatar
Roco71
Summit racing has a pretty good selection of headers starting at $89.00
Old Feb 8, 2010 | 04:31 PM
kmobrien76's Avatar
kmobrien76
FOund them: http://www.summitracing.com/parts/SUM-G9003/?rtype=1
they look fine for the $..
hmmmmm to mod or not to mod that is the question!
K.O.
Old Feb 8, 2010 | 04:57 PM
Roco71's Avatar
Roco71
Sounds like the mods have already started. If you go for it save all the original parts you never know. Does your car have AC? If so you will need AC brackets and in some applications an alternator bracket. Upside to headers more HP and better fuel mileage (if you can keep your foot out of it) and that sound….. That sound of power. The down side is they put off a lot of heat .
Good luck
Scott
Old Feb 8, 2010 | 05:37 PM
kmobrien76's Avatar
kmobrien76
No A/C
I don't mind a bit more heat, that's alright...
Am I guaranteed a much louder/throatier sound even from the $89 SUmmit headers noted above?
Kevin
Old Feb 8, 2010 | 05:42 PM
Roco71's Avatar
Roco71
The mufflers you use will make a difference in the sound. Anywhere from a rumble to rolling thunder.
Old Feb 9, 2010 | 12:07 PM
kmobrien76's Avatar
kmobrien76
Has "newer" mufflers on it, previous owner's receipts show them as "turbo mufflers" whatever that means...has a nice sound now but want it louder/throatier...
Kevin
Old Feb 9, 2010 | 02:19 PM
Roco71's Avatar
Roco71
Hey Kevin,
Do you know what size of pipes your are running? If you go with the headers and want more sound you may want 2 ½ inch exhaust pipes if you do not already have them.
Scott
To Sound - headers?
