Grease for tach/speedo cables?
Old Feb 17, 2010 | 04:51 PM
nw2571's Avatar
nw2571
Default Grease for tach/speedo cables?
Anybody have a go to grease to help with bouncing tach or speedometer needles?
I recently picked up one of these:
http://www.mamotorworks.com/corvette-4-327-1170.html
I'm thinking general purpose type grease is too viscous, and white lithium grease is the way to go. Can't seem to find any tubes of white lithium to put in a grease gun for the fitting adapter I bought.
Old Feb 17, 2010 | 08:26 PM
7T1vette's Avatar
7T1vette
Squirting grease into the cable casing is NOT the way to go. You can remove the cable from the casing [difficult] and put a light wipe of lithium grease on it...OR...many suggest using a dry lubricant like graphite on it. If you put a significant amount of grease in the casing, the cable will bind up as the grease dries out and gets sticky.
Old Feb 17, 2010 | 08:33 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've used the graphite with success.
Old Feb 17, 2010 | 08:37 PM
dannyman's Avatar
dannyman
I'm with you Skunkworks!
Graphite won't gum-up down the road.
Old Feb 17, 2010 | 08:47 PM
southern_vette's Avatar
southern_vette
if its jumping badly, you might want to pull it out, look for kinks, and look for places in the cable covering for warn through spots.
Old Feb 17, 2010 | 10:26 PM
nw2571's Avatar
nw2571
Removing the cable from the casing and rubbing it down, or spraying some graphite into the ends?
Old Feb 17, 2010 | 11:47 PM
noonie's Avatar
noonie
Always just used the graphite powder.
Old Feb 18, 2010 | 06:56 PM
TheSkunkWorks
I guess you'd say I did more of a rub down method, during which inspecting for any kinks, but I wouldn't load it to excess.
Old Feb 19, 2010 | 10:34 AM
Wuttin's Avatar
Wuttin
remove cable from casing
To Grease for tach/speedo cables?
