Engine date code question
Old Feb 22, 2010 | 04:57 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
The two letter code only identifies the engine the label is supposed to be for.
....just off of the top of my head my '75's two letters on the emission label are "AU".
...it is just a broadcast code. Even the original tire pressure labels had broadcast codes.
Old Feb 22, 2010 | 05:37 PM
joewill's Avatar
joewill
according to my black book, 13350 is a Feb 72 built VIN. Birthdate around feb 9th.. makes the trim tag stating 'C03' extremely suspect.. now a december built engine assembly 8 weeks prior becomes feasible ( 7 weeks prior if you count the usual Xmas 1 week shutdown.. did they do that back then?) but the '1' in front of the stamp would alert me to some deviation also.
looks so far like a real LT1 with AC but with a obviously wrong trim tag and a funky engine assembly stamp.
we could sure use photos of trim tag, engine stamp and block date code...
Old Feb 22, 2010 | 05:40 PM
Ravine Speed's Avatar
Ravine Speed
Originally Posted by vettes4evr
The full VIN is 1Z37L2S513350. The engine block casting number is 3970010. I'm waiting for the date code from the rear of the engine block also. As I said, car was built on Sept. 3rd, 1971.
According to that VIN, the car was built in Feb '72, approximately the 9th of Feb. Better take a closer look at the trim tag.
Old Feb 22, 2010 | 05:47 PM
Ravine Speed
I bet the trim tag is a "G" for Feb., not a "C" for October.
Old Feb 22, 2010 | 10:12 PM
vettes4evr's Avatar
vettes4evr
I'm still waiting to hear back from the dealer on the block casting date and exact pad number. But in the meantime I found something else suspicious. The VIN number on this '72 LT1 is 513350 (13,350th made). According to the Black Book, this would put it's production in Feb.'72. BUT the trim code tag has CO3, which is Oct.3,1971. Therefore its VIN number should be about half of what it is. The block stamped VIN matches the VIN on the pillar post. So...what about the possiblity of someone placing that LT-1 engine (and possibly trans, which wasn't checked) with a matching VIN tag into a regular '72 Corvette body. Without being able to view the VIN stamped in the frame rails, I guess it's difficult to prove huh? Man, this thing is getting ugly.
Old Feb 22, 2010 | 10:17 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Dude, we need pictures! Pictures of the important numbers. Pictures of the engine itself. Look at the two posts prior to this one. Sometimes, letters can be hard to read. The experienced folk here will know what to make of your trim tag, stamp pad, casting date etc. when THEY SEE THEM! This is not a criticism. They want to help you, just help them help you
Old Feb 22, 2010 | 10:33 PM
vettes4evr's Avatar
vettes4evr
Yep. I know. I'm waiting for the pics. What can I say... I forgot the camera at home!! Plus I had cataract surgery recently and can't see very good close up. I should have felt the numbers like braille and written them down. But hey, aren't these mysteries FUN!?
Old Feb 23, 2010 | 08:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Feb 23, 2010 | 10:35 AM
Mike Ward's Avatar
Mike Ward
The trim tag showing a G makes much more sense. The only unexplained feature is the extraneous 1 at the beginning of the engine machine code. Is it possible that the pad is a factory re-stamp and that the 1 is a leftover from the 1st stamp??
Old Feb 23, 2010 | 12:00 PM
jaki30's Avatar
jaki30
Default Check the other things
Besides the "L" in the VIN denoting the LT-1 engine, there are a number of 'one of' items for a true LT-1 car. If the car is really an LT-1 A/C car, (the VIN with the the L in it) will also have the lower RPM tach and a 3:55 rear end (the only one available with the A/C LT-1).
Also, if you lift the rear rug the fiberglass next to the three storage compartments will have "C 60" painted on the floor to inform the production people to seal the astro ventilation flaps under the rear window. A/C LT-1s were only produced between Jan 72 and Apr 72.
Old Feb 23, 2010 | 12:48 PM
vettes4evr's Avatar
vettes4evr
My error. The engine numbers located on the boss on the right side of the engine are V1213CKY there is nothing before the V.
The engine number is stamped 12S513350 – The code for that is 1 Chevrolet Division, 2 Model year 1972, S manufactured in St. Louis and the last six production sequence numbers (13,350).
The number in the rear of the block near the bell housing is LT010. The "T" could be a "1" and the last zero may or may not be accurate. It is very difficult to see. Can someone interpret this?
The trim plate is "G03" indicating that the engine was produced in February of 1972. The engine being produced on December 13 of 1971 and the car being manufactured in February is starting to make more sense especially if they stopped or reduced output between Christmas and New Year’s. If someone could make sense of that date code on the back of the block it might be the last clue to match the engine to the body. And that mark under the carpet is an excellent point. I'll try to check that out.
Old Feb 23, 2010 | 02:57 PM
Derrick Reynolds
There should be two numbers at the back of the block, one a part number, the other a casting date. "LT010" doesn't sound like either one. If it instead says "L 10 1", that would be a casting date (assuming a proper part number) of December 10th, 1971.
If that is true, and you have engine assembly of 12/13/71, and trim tag date of 2/3/72, then your dates are in the right order (casting before engine assembly, engine assembly before body build).
Old Feb 23, 2010 | 04:30 PM
  #33
joewill's Avatar
joewill
This entire thread has been based on misinformation posted in the 1st post...
sounds like a rare, early AC LT1, are you going to buy it?
