Possibly the dumbest engine question
Old Feb 26, 2010 | 12:14 AM
TimAT's Avatar
TimAT
Originally Posted by damoroso
Love the pic!! Yep, that's why they're called "Big Blocks"!!
And not just everyone has a SB and a BB just hanging around waiting on a PHOTO OP!!!!
Old Feb 28, 2010 | 10:17 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Originally Posted by RobRace10
Does this help 350 vs 427
sweet!!!
Old Mar 1, 2010 | 09:21 AM
alswagg's Avatar
alswagg
Note, 8.1lt is a 496 Big Block.
Old Mar 1, 2010 | 11:46 AM
joewill's Avatar
joewill
I believe Ford and MOPAR have small and big blocks also.. alot of this is early naming from even prior 55 to 80's.. who knows what you call a modern Ford, Mopar, or GM.
Old Mar 1, 2010 | 02:40 PM
Jay-Dog's Avatar
Jay-Dog
ok guys, how about Ford? Clearly, a 260-289-302 is a small block. Clearly, a 429 is a big block. What about the 352-390-428CJ FE blocks? What about a 351 Cleveland? Back to the original post, is there a definitional difference besides "its bigger"? For instance, a 351 Cleavland vs. a 351 Windsor? Windsor bore & stroke is X:Y and Cleveland bore & stroke is Y:Z.
Jay
Old Mar 1, 2010 | 02:53 PM
Jay-Dog's Avatar
Jay-Dog
Jay
Old Mar 1, 2010 | 05:24 PM
toddalin's Avatar
toddalin
Jay
Same as the Chevys..., bore spacing.
Old Mar 1, 2010 | 05:36 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Jeebus, you guys omitted an entire engine family.....
Old Mar 1, 2010 | 05:47 PM
noonie's Avatar
noonie
Jay
Ford just had too many different blocks.
352-390-428 are bb
Cleveland- bb
windsor-sb
All the big blocks weren't the same configuration.
Old Mar 1, 2010 | 10:36 PM
toddalin's Avatar
toddalin
352-390-428 are bb
Cleveland- bb
windsor-sb
Cleveland is a small block as is the windsor and midland.
Old Mar 2, 2010 | 12:07 AM
noonie's Avatar
noonie
If you ever had a windsor vs a cleveland in an older mustang you wouldn't think the cleveland is a small block. It does share the smaller bell housing pattern though and motor mounts, but very few other parts.
Basically old Ford had 3 different size families of engines, not called small block or bb, that's just for Chevy guys.
I was wrong in calling them sb or bb.
Windsor (221/260/289/302/5.0L/351W/5.8L)
FE (mainly 390/428)
335 (351C/351M/400) (Cleveland, Modified)
385 (429/460)
BTW, Last year I sold my Pantera (Cleveland), that I had for over 35 years.
I always likes the clevelands.
Old Mar 2, 2010 | 01:57 AM
toddalin's Avatar
toddalin
FE (mainly 390/428)
385 (429/460)
As I noted, it is the bore spacing. From Wikipedia:
When the 351 Cleveland was withdrawn after the end of the 1974 model year, Ford needed another engine in the 351 cubic inch (5.8 L) class, since production of the 351 Windsor was not sufficient and the 390 FE was being retired as well. To replace the 390, Ford took the 400 engine's tall-deck block and de-stroked it with the shorter throw crankshaft from the 351 Windsor, and taller pistons, to produce a 351 cubic inch (5.8 L) engine whose components were largely compatible with the 400. This engine was called the 351M and as a back-formation the taller-deck block became known as the M-block.
If the Windsor crank fits the Cleveland block, they share the same bore spacing and are therefore both small blocks.
Old Mar 2, 2010 | 08:37 AM
  #33
krz-fasc3's Avatar
krz-fasc3
GEEZ!!!! Nobody get started on rat vs mouse please.
Old Mar 2, 2010 | 03:06 PM
  #34
skaping's Avatar
skaping
QUOTE=toddalin;1573277944]As I noted, it is the bore spacing. From Wikipedia:
If the Windsor crank fits the Cleveland block, they share the same bore spacing and are therefore both small blocks.[/QUOTE]
Cleveland heads are much bigger than windsor heads which ceates the illusion of a bigger engine. Head size is an easy way to identify Chevrolet big blocks, but means nothing on the ford engines.
Old Mar 2, 2010 | 04:28 PM
  #35
whitehause's Avatar
whitehause
Big block--- 7 valve cover bolts. 3 on top 4 on bottom
Small block---- 4 valve cover bolts 2 top 2 bottom
easiest way to tell
