Well, the disclaimer is in the title, so here it goes. What determines if a certain engine is a big block or a small block.
It seems like it should be obvious, but I can't figure it out. Wikipedia was kinda blurry on it. I always used to think a big block was an engine of at least 5.7L (or so) with a stroke bigger than it's bore. What started me thinking about this was my considering a 383 stroker kit for my 350 in my vette. That would make it a big stroker motor, but still a small block.
Confusing me more is the fact that chevy makes only small blocks now, and they range up to 427. I always think of anything over the 400 range as big block territory. I think they called the 8.1 a big block though? So maybe the terminoligy use to hold merit in the 60's, but it is only a marketing scheme now. Call the big truck motor a big block to imply stump pulling raw torque, and call the car motor a small block to imply fast rapping drag racing.
I don't know if this the right place for this thread. and sorry if it is a stupid question, but you couldn't have been expecting too much if you clicked on this thread.
A big block is a 396, 427, 454, or 502. I think there might be a 572 now too. The small block is a 262?, 283?, 302, 305, 307, 327, 350, 383, 400. I probably missed a couple but that's the general idea.
They are easy to tell apart by the size of the valve covers. Big blocks are big and small blocks are small.
I was hoping it was that simple. So is an old 427 noticably bigger than a new LS7 427?
Completely different animal. The old 427 is a Big Block and the LS7 is small block. Like they said above, look at the valve covers. There is no mistaking a BBC from a SBC...
The physical size.
The history of the SBC has been one of ever increasing displacement.
....I always used to think a big block was an engine of at least 5.7L (or so) with a stroke bigger than it's bore. What started me thinking about this was my considering a 383 stroker kit for my 350 in my vette. That would make it a big stroker motor, but still a small block.
The bore to stroke ratio has nothing to do w/ big or small block.
When the BBC was designed it was 427CI & the SBC was 327 C.I., then the SBC went to 350 or 5.7L.
Then a 400 SBC was done & the typical BB was around 400(+) C.I. displacement.
The small block and big block castings are completely different. Small blocks began with the original 265 cu in V8 in the mid-50's and were used through the 350 cu in (like in our C3 cars) and 400 cu in series into the 80s. Modern Corvette blocks are different casting designs, even though they may be of similar displacement. The "big blocks" began in the mid 60's with the 396, 427 and 454. Prior to that there were some "W" block designs [originally for truck engine use] comprised of the 348, 409 and 427 (early). They were good for cubic inches, but not for durability and were dropped from car lines when the 396/427 BB engine was developed. Hope that helps.
The easiest way to tell them apart by glancing at the engine is to look at the exhaust ports. On a Chevy big block, the exhaust ports are evenly spaced. On a small block, the two middle ports are right next to each other.
As I noted, it is the spacing of the cylinder bores that determies a BB from a SB.
Small blocks are spaced at 4.40 inches which typically limits the bore to ~4.155" and big blocks are at 4.84" which effectively limits the bore to ~4.65".
Heads, valve configurations, and the like have nothing to do with this designation.
The heads are completely different, which causes the valve covers to be vastly different as well. This is probably the easiest way to tell the difference between bb and sb without taking anything apart or measuring anything. BB valve covers have seven bolts. Small blocks typically 4 unless your talking about the newer generation LS small blocks, then the bolts go through the tops of the valve covers. The BB valve covers are much wider becuase the valves in the head are stagered, unlike the small block which are all in a straight line. All the other things stated about the blocks are certainly true, but you can't see that from the outside.
The valve covers are the easiest way to identify a big block. They are just bigger and so is the block. After awhile you'll be able to spot the big blocks immediately. Modern LSX small blocks can get up to 502 cubic inches, so it has nothing to do with displacement anymore. They also have even exhaust port spacing.
See, there were some people here who didn't know either so it wasn't a stupid question.
I took the picture as someone said there wasn't much difference in size. So I posted a picture like that one and then they said that it was because they were at different heights the BBC looked bigger, which they weren't so I put the tape measures on the crank center-line and matched the fronts of the motors up. You sure can tell the difference in the head weights and the block when working on them!
Not exactly. That would be true of small blocks 1955 through the mid "90s (LT1 & LT4 etc. but LS series small blocks are staggered ports like the big blocks.
