door hinge pins
Old Mar 1, 2010 | 11:21 AM
tomgallucci57's Avatar
tomgallucci57
Default door hinge pins
hello all, when replacing the door hinge pins and bushings, is it as simple as poping out the old ones,and putting in the new. or will i have to remove the whole hinge from the car, its a 68 t top thanks tom
Old Mar 1, 2010 | 11:27 AM
zwede's Avatar
zwede
The lower hinge can be done without removing it from the car. The top hinge has to be removed from the car to get the pin out.
Old Mar 1, 2010 | 11:46 AM
tomgallucci57
Default of coarse
it did look a bit tight up there,thanks
To door hinge pins
