frame treatment
Old Mar 11, 2010 | 05:02 PM
ts_vette_st's Avatar
ts_vette_st
Default frame treatment
What is the best way to treat surface rust on the frame of a driver car? I have no intention of doing a frame off power coat or paint. I want something to treat as best as possible as car sits. Thanks!
Old Mar 11, 2010 | 05:07 PM
michalbugno2006's Avatar
michalbugno2006
If you don't intend on painting the frame how are you wanting to protect it?
Old Mar 11, 2010 | 05:13 PM
ts_vette_st
I can paint I just don't intend on removing the entire body to do it. What I was wondering is what others that have non-show cars have used to paint, undercoat, oil, etc to protect the frame as well as possible without spending months disassembling the entire car to do it. And what technique they used to get the best coverage possible. Thanks!
crvtownr's Avatar
crvtownr
If you don't want to do anything else to it, I would recommend naval jelly. You can get it just about anywhere including home depot, etc. However, the rust will return without sealing it with something.
Old Mar 11, 2010 | 07:05 PM
pwsusi's Avatar
pwsusi
put the car on a lift or jack stands and get wire wheel brush that attaches to a drill (from any home improvement store). use that to remove the surface rust and then paint the frame with rustoleum semi-flat black paint. you're not going to be able to get at all the tight spots and get everything like you would with a frame off, but you should be able to clean it up nicely provided the rust is only minor.
before..
after...
Old Mar 11, 2010 | 11:55 PM
7T1vette's Avatar
7T1vette
Once you clean the grease and gunk off the frame, use a wire brush (powered or manual) to knock off any loose rust. Don't worry about the light surface rust, because your next step is to put some "rust converter" on the areas with surface rust. That stuff chemically converts the rust to an inert material which seals the surface, as well. That converted layer will act as a primer to which you can add whatever paint you want to use. [P.S. If you have other areas that are un-rusted bare metal, you need to prime them before painting.]
Old Mar 12, 2010 | 01:46 AM
jordan89's Avatar
jordan89
Old Mar 12, 2010 | 08:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Wire brush it and paint it. Get comfortable because you're going to be under there a looonnnggg time.
Old Mar 12, 2010 | 09:01 AM
joewill's Avatar
joewill
this is the best job of a non frame off of masking and painting I have seen.. it can be done.
http://www.julietpage.com/corvettes/...p/rearsusp.htm
Old Mar 13, 2010 | 09:42 AM
73 stingray's Avatar
73 stingray
Eastwoods should help look them up on the internet
Old Mar 13, 2010 | 05:04 PM
71coupe454's Avatar
71coupe454
Permatex makes a rust treatment/converter in a spray can that works great. Just scuff off the loose rust and spray it down with that. Then you can spray can black over it.
Old Mar 26, 2010 | 10:35 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
What I have done is to use an assortment of wire brushes including manual and with a drill. When I am satisfied with the cleaning, I finish the job with laquer thinner and some rags.
I paint my frame with a specialty rattle can from Rustoleum. It is an epoxy spray paint color called stainless steel. It dries very quickly and looks very nice.
I just do a small area at a time. This is not a fun job and so I will only do it when the mood strikes me. My frame has NO rust so I am only cleaning off the years of grease and grime. An hour or so now and then is the strategy for me.
How do you eat an elephant? One bite at a time..........
To frame treatment
