Sorry about the new thread, but the other didn't really tie in so I thought it best to start a new one.
Last summer, I was constantly tightening my valve cover bolts. I was told that the reason they loosen up is because as the engine heats up the engine threads (The hole) expand, which makes sense.
So, I'm wondering if I could use some of the weak lock tite glue so the bolts will stay in place. There are different adhesive factors and thought the Blue version would work.
I just tighten mine up every now and then. Your old gaskets are likely cork and are shot...father time and too much heat. You may have over-tightened them as well, causing the situation to be worse. Use a small ratchet with an extension and one hand to "sung" them up. If you over-tighten them the gasket will compress and start to leak again. Take your time, if you're like me, evertything I take off is clean as the day it left the factory before I put it back on.
Are you using the little metal "load spreaders" or flat washers under the valve cover bolts? Are you torquing them to proper specs? Generally, they loosen up because they have been overtightened in order to get the gaskets to seal. If you have stamped steel covers, it is likely that they are dimpled/bent under the bolts and that the areas between bolts will not seal. I don't know if this is your problem or not, but if so, the valve cover rails need to be flatened out, the engine and valve cover [gasket] surfaces need to be cleaned with solvent to get them oil-free and dry, Fel-pro gaskets need to be installed, load spreaders or washers need to be under the bolts and the proper torque applied; then they will seal.
Well, you can still overtighten them...which will stretch the bolts and cause them to eventually lose torque. The best way to keep them from loosening is to use the parts that the factory used and torque the bolts properly. If the bolts you have were overtorqued in the past, throw them away and get some new bolts.
