I changed low to off a long time ago.
Blower A/C Vent
Low to Off
There is a 4 wire T connector at resistor connection on A/C evap. box under hood on pass. side forward of the high blower relay & hood spring. Pull connector & bend down the connector to dk. brown wire & reconnect.
Forward speed will push air through the system even w/ blower off on vent.
