Door ajar switch electical connectors...
Old Mar 16, 2010 | 11:33 AM
MakoShark72's Avatar
MakoShark72
Default Door ajar switch electical connectors...
I have new switches and new electrical terminals.....
The terminals have a U-bend at the end. When I shove the new terminals into the slot in the new switches, does it matter which way the U-bend goes.
Looks like the U-bend is supposed to help keep the terminal end from sliding out when the switch compresses and decompresses. I tried it both ways and the terminal slides out either way I install it.
Any help much appreciated!
Rob
Old Mar 16, 2010 | 11:43 AM
TimAT's Avatar
TimAT
I replaced a couple of those terminals on the 74 when I replaced the harness. Looked to me like the best way was with the open side of the U facing away from the center, and then that open end hooking over the edge. May not be correct, but it looked to me like the way to get it to work.
Old Mar 16, 2010 | 12:25 PM
MakoShark72
Tim,
Thought about that too... but I dont recall them that way when I took them out so many months (years) ago...I recall they were totally in the plastic, and were sort of difficult to pull out...
Thanks,
Rob
Old Mar 16, 2010 | 04:39 PM
Alan 71's Avatar
Alan 71
Hi Rob,
My understanding is that the connector is 'one time use' only.
The barbs on the connector catch in the 'slot' in the nylon switch body and hold the connector in place.
That's why the vendors list the cinnectors right after the switches.
Regards,
Alan
Old Mar 16, 2010 | 06:29 PM
MakoShark72
Thanks Alan,
Problem is... when I insert the terminal into the switch, nothing "catches"... slides in, slides out. Maybe I should "modify" the little barbs....
Rob
Old Mar 16, 2010 | 06:43 PM
TimAT's Avatar
TimAT
I have had to "raise" the barbs on some of those snap-in connectors. Not very much but a little bit. Might be the cure to get yours to lock.
Old Mar 17, 2010 | 11:02 AM
Alan 71's Avatar
Alan 71
Since I'm only allowed to do things in an 'original' way, I can't modify anything!!!!
Just kidding, Tim's slight bend sounds like a reasonable solution.
Regards,
Alan
Old Mar 17, 2010 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could be your new terminals. Mine plugged up just as Alan shows. I got them from Eckler's, but it was the late 80s when life was kinda-sorta okay a little.
Old Mar 17, 2010 | 07:15 PM
GD70's Avatar
GD70
Originally Posted by Alan 71
Hi Rob,
Regards,
Alan
Those are good pics Alan! I need to replace both of mine. Left one is MIA, the right doesn't spring out or light up the dash light if I pull it out.
Old Mar 17, 2010 | 10:40 PM
hwcoop's Avatar
hwcoop
in case you want to see whats behind the panel....
Old Mar 18, 2010 | 11:54 AM
Alan 71's Avatar
Alan 71
Hi HW,
I'd say you cut an ACCESS PANEL!!!!!
Regards,
Alan
Old Mar 19, 2010 | 10:41 AM
hwcoop's Avatar
hwcoop
Hi HW,
Regards,
Alan
I removed it with a heat gun when I was replacing my rocker channels and it gave me the opportunity to repair my Door ajar switches.
The metal backing was stripped and rusted so i fabricated new ones out of 10ga, drilled and tapped to allow new switches to screw in then riveted them to the body.
I went to the wreckers and found door switches of 70 & early 80's GM cars would work and made sure to retrieve some of the harness from the doner car.
Just one of those little things that are nice when they work.
Old Mar 19, 2010 | 01:44 PM
GD70's Avatar
GD70
WOW! Did you need to replace the #3 mount with one of those steel replacement inserts?
Glenn
Old Mar 19, 2010 | 05:29 PM
hwcoop's Avatar
hwcoop
Glenn
sure did...
http://forums.corvetteforum.com/c3-g...el-mayhem.html
Had so much fun I decided to help my Buddy do his 72 Coupe, new frame, C4 suspension, 383 & 5 speed pics to follow...
Old Oct 15, 2011 | 01:56 PM
kaiserbud's Avatar
kaiserbud
Rob ... I am having that same issue. I believe that the plastic on the new ones is too soft. The old original ones I have still work (the plastic anyway)...
So - how did you resolve Rob? I did bend the 'finger' out a bit, but it does not want to catch.
Alan - did your connectors protrude a bit - or just barely above beoing flush? Great pics.
Old Oct 15, 2011 | 07:08 PM
Alan 71's Avatar
Alan 71
Hi kb,
I really can't remember, (and can't take a look), how far the blade protruded. Doesn't it have to protrude a bit so the plunger touches it and makes the connection?
Regards,
Alan
Old Oct 16, 2011 | 03:55 PM
kaiserbud's Avatar
kaiserbud
I think the connector metal (Lectric Limited) is greatly inferior to the OEM connector. As for the plastic for the switch (Corvette Central) , I feel it is also softer than the OEM switch plastic.
I think the trick is to 'pull back' the switch plunger assembly so that when you insert the connectors, you are not mashing them up against the bottom of the plunger area. That way the end of the connector protrudes a bit and seats well - rather than distorting the plastic or the prong.
I was successful at getting all 4 door switches working, but it was a hodgepodge of variables.... unfortunately. They work great now. I do have a set of metal connectors that I can solder on, and I will do that at a later date.
Oh - Alan - if you look closely at your picture that has teh complete assembly hanging out - I believe you can see that the connector does protrude a bit once properly seated.
Learning as I went, here is how mine played out:
The prongs broke off soooo easily on the first LR Door Ajar Switch, so I re-inserted with the pronges pointing outwards and once through the plastic in the switch, I slightly bent them outward. On the RR Door Ajar, with the connector prongs intact, I inserted the connectors with the 'finger' facing out. Still learning and wanting to ensure they stayed, I slightly bent them away from the center post on the switch. The RF Courtesy Switch was only one wire and it actually stayed stuck into the plastic switch. The LF Courtesy/Key Buzzer required me to bend the prongs outward a bit as before.
I also removed the #3 Body Mount cover and inspected for the seals. I also added some shrink tube around the wires. I heated so that only a small 1/2" area was shrunk around the wires. The rest of the shrink tube acted as a buffer and had airspace around the wires.
BTW - that key buzzer noise is annoying and kinda weenie/sickly sounding.... is that coming form the horn relay?
To Door ajar switch electical connectors...
