Radiator support
Old Mar 16, 2010 | 04:30 PM
mrit's Avatar
mrit
Default Radiator support
I gotta replace the radiator support in my '75, The entire bottom part is rusted out. I found an awesome deal on one from a '80, but have read there are differences between it and mine. If I have read the 100 or so threads correctly, I can use the '80 support and radiator and it should bolt into my '75 right? I have no plans on leaving the vette stock, I just want to have something that works good without hacking anything up.
Old Mar 16, 2010 | 06:10 PM
gbvette62's Avatar
gbvette62
The 80 core support and radiator should work, but you'll need to use the 80 shrould with it also. The 75 shrould will not attach to the 80 support. If you can't get the shrould with the support and radiator, be aware that a new one is about $400.00.
You'll probably need to use the 80 upper and lower hoses, too.
Old Mar 17, 2010 | 05:25 AM
mrit's Avatar
mrit
Good point... Crap I didn't even think of that.
Looks like it will be cheaper just to get the new radiator support from wilcox or someone.
Old Mar 17, 2010 | 08:42 AM
corvetteload's Avatar
corvetteload
AND YOU UST USE THE SHROUD, or overheating will occur. I have an NOS support and NOS shroud (2 pieces), make an offer.......................
Old Mar 17, 2010 | 06:20 PM
markdtn's Avatar
markdtn
The 76L-81 core support will work in an earlier car. The shroud is different as noted. The later one also uses different style radiator mounts also. Not a big deal, but different.
Old Mar 18, 2010 | 09:38 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...I've changed the core support on my current '75 coupe and on the Yellow 4spd '80 that I used to own. It is much easier and less headache if you replace the core support with the one that's exactly like the present one in your car. Not a bad job, took about 6hrs for each car doing it carefully and right the first time.
To Radiator support
