Lost Steering Temporarily
Old Mar 17, 2010 | 05:58 PM
sfore93392's Avatar
sfore93392
Default Lost Steering Temporarily
I was out for a drive in my "72" when I went to make a left hand turn and the car did not respond immediately. It steered fine after that and I thought that maybe it was my imagination but then it happened again a month later. I am thinking the steering box needs to be rebuilt or replaced. Has anyone experienced the same thing or have any ideas on what might be going on.
Old Mar 17, 2010 | 06:59 PM
Gordonm's Avatar
Gordonm
Check the rag joint. The coupler from the steering shaft to the steering box.
Old Mar 17, 2010 | 07:05 PM
7T1vette's Avatar
7T1vette
I can only believe that the "ragjoint" steering coupling between the steering column shaft and the steering box is nearly disintegrated and would allow such a situation to occur. You should not drive the car unless you are going to a mechanic to get it checked out properly...and then you should drive carefully. You can look at the ragjoint and see if the fiber coupling looks like it is damaged. You can also have someone attempt to turn the steering wheel while you are looking at the ragjoint to see how much movement it has. With the engine off, you should not be able to turn the wheel much at all with normal steering effort.
Old Mar 17, 2010 | 08:02 PM
08vycpe's Avatar
08vycpe
There is a high spot in the gear mesh at TDC in the steering box. If the steering gear was adjusted at anything but TDC you might get a bind as it crosses TDC. I would get the front wheels off the ground and go through Jim Shea's papers about the rag joint and the steering box adjustment.
Afterthought: You might want to check to see if you have any lube left in the box as well. If it was just hard to steer in a turn for a second it could be a PS issue as well.
Old Mar 17, 2010 | 10:35 PM
my 76 ray's Avatar
my 76 ray
What do you mean by "did not respond immediately"? Did the steering wheel turn but the car didn't or were you unable to turn the steering wheel? If the steering wheel turned but the car didn't, how far did the steering wheel turn before the car turned?
Old Mar 18, 2010 | 07:24 AM
Jim Shea's Avatar
Jim Shea
If your power steering fluid is low, you can sometimes suck air on a hard turn and you might lose power assist briefly. I would expect that your power steering pump would make a lot of noise for a short time thereafter if it had sucked air.
A good inspection of your steering and front end parts is in order.
Jim
Old Mar 18, 2010 | 07:32 AM
joewill's Avatar
joewill
Yes, the OP seems a little vague.. when driving down the street, can you not turn because it is too hard to turn the steering wheel? Or, when you spin the steering wheel, did you still go straight?
Old Mar 18, 2010 | 09:14 AM
sfore93392's Avatar
sfore93392
I turned the steering wheel but the car kept going straight or veered just slightly in the direction I wanted to go. I can't remember if I turned the steering wheel back straight or turned it more in the direction I wanted to go but I made the turn. After the turn as I was driving down the road I turned the wheel to the right and left and the car drove fine. Thats when I thought I sort of doubted what happened until it happend a month later. I have had the car put away for the winter but will take it to my Vette specialist to have them take a look at it.
Old Mar 18, 2010 | 10:56 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Stripped or wrong sized splines at the steering wheel hub ,just below the wheel are another area to look at.
I installed a new steering shaft in a C2 awhile back and the spline diameter was the wrong size. Didnt notice that till a month after the customer was driving it.
To Lost Steering Temporarily
