Need Wiring Help! Please!
Old Mar 20, 2010 | 01:55 PM
NCLT1Vette's Avatar
NCLT1Vette
Default Need Wiring Help! Please!
Ive had this apart for way too long so its time to get it sarted!
Its a 71 LT-1 but the TI has been replaced with a standard points setup (TI will get installed another day)
I replaced the engine wiring harness and the dash harness.
The last wire I cant place is the RED wire that comes from the dash harness thru the firewall gromet that also contains the oil pressure line.
Its a heavier guage red wire and i can't seem to find any place to put it. I believe it goes to the TI setup and not used in a points setup but not sure.
I can uplaod a picture in a few.
Thank,
Ron
Old Mar 20, 2010 | 02:11 PM
oldsarge's Avatar
oldsarge
Is it the one that would go to the large bottom connector of the horn relay, that is on the left fender, just behind the wheel well? Just a guess.
Old Mar 20, 2010 | 03:01 PM
Alan 71's Avatar
Alan 71
Hi,
From what I can find there are 3 wires that may come though that grommet. The wirering for the LT-! option isn't shown in the AIM.
The back-up light connection, all cars.
A wire when the M-40 Auto is an option.
A wire that runs to the hood switch for the alarm option.
Thats all I see.
Regards,
Alan
I believe all the wires for the horn relay are in the foward lamp harness except for 1 heavy wire from the engine harness. I guess your wire is supposed to be headed forward to the TI amplifier.
Old Mar 21, 2010 | 06:14 PM
NCLT1Vette's Avatar
NCLT1Vette
Thanks all, the car is running! without the wire so I believe it goes to the TI ignition...Ill save that for another weekend when i've got some extra help.
I'm just happy it's running....first time in two years, fired right up with no porblem...took it out got some gas and had a little fun!!!!
Thanks,
Ron
To Need Wiring Help! Please!
