Electric fan temp switch ?
Old Mar 20, 2010 | 10:15 PM
toyvet1's Avatar
toyvet1
Default Electric fan temp switch ?
I have spal elecrtic fans and will be installing a 160* thermostat. What temps do I want for the dfan switch? On at 200 off at 180 ?
Old Mar 21, 2010 | 09:30 AM
thegazman's Avatar
thegazman
Default thegazman
With a 160 degree thermostat I would go with a 180/165 temperature switch.
Old Mar 21, 2010 | 11:26 AM
toyvet1's Avatar
toyvet1
So your thinking is that on cruising speed on a hot day the car should run at 160 ? Ive never had the car able to run below 175 so the fans would always be on.
7T1vette's Avatar
7T1vette
Best operating temps for the Chevy engine is around 180F. Putting in a 160F thermostat won't 'harm' anything, but the cooling system probably won't stabilize there...unless you have an over-engineered system {excess rad capacity, etc.). So, I'd suggest that 200F-ON and 180F-OFF switch would be a better choice for you. I doubt that the 165F-OFF switch would ever be needed; your fan would likely stay ON all the time. If you choose to go with a 180F stat, the 210F-ON, 190F-OFF switch would be my suggestion.
Old Mar 21, 2010 | 02:47 PM
thegazman's Avatar
thegazman
Default thegazman
This is true. But, if you are in city traffic and the fan doesn't come on until 200 degrees you be running around town in the 200's. The 160 thermostat doesn't mean that the engine will run that cool.
Old Mar 21, 2010 | 11:29 PM
glen242's Avatar
glen242
I have a 180* thermostat. Where can I find a 210 -on, 190-off? Brand, part #, etc.
Thanks,
Old Mar 21, 2010 | 11:35 PM
glen242's Avatar
glen242
Why is running at over 200* but less than 230*-240*, bad? I believe that HOT on the temp gauge is 250*.
BTW, using a 180* thermostat.
Old Mar 21, 2010 | 11:40 PM
glen242's Avatar
glen242
If the best operating temperature is around 180*, why did they install 190*-195* thermostats, at the factory?
Old Mar 22, 2010 | 09:15 AM
thegazman's Avatar
thegazman
Default thegazman
I don't think your V-8 is going to run as low as 180. At the same time I don't want my car running 220. I prefer 190 - 200. They installed higher temperature thermostats at the factory for smog purposes. They did a lot of things for smog purposes and a lot of them affected your engine performance. Like moving your vacuum advance from the manifold to a ported vacuum on the carb to retart your timing at idle.
Old Mar 22, 2010 | 10:13 AM
7T1vette's Avatar
7T1vette
195F stats were mandated by EPA because hotter running engines burn off more hydrocarbons. That is also why the early '70s C3's had the TCS emissions system. That was designed to cut-off dist. vacuum advance in lower gears so that the engine would retard and run hotter at idle and city driving...for that same reason. Apparently, the car companies were OK [not happy, mind you] about engine temps going up because it only hurt fuel mileage. It probably hurt engine life, too; but, back then, the warranty was only for 3 years or 36,000 miles [some were 5 years 50K mi. on drivetrain].
To Electric fan temp switch ?
