73 headlight switch
Old Mar 23, 2010 | 07:12 PM
wmkj69's Avatar
wmkj69
Default 73 headlight switch
I need to replace the headlight switch on my 73. What do I need to remove to get to it, or is there a trick?
Old Mar 23, 2010 | 08:10 PM
mzmgb's Avatar
mzmgb
Removing the top dash pad will give the best access.
Old Mar 23, 2010 | 09:55 PM
Tom73's Avatar
Tom73
You need access to the behind the panel part of the switch, then there is a button to release the push/pull plunger. With that out you can remove the bezel and then the switch.
Old Mar 28, 2010 | 07:31 PM
wmkj69's Avatar
wmkj69
How do I remove the top dash pad
Old Mar 28, 2010 | 08:47 PM
...Roger...'s Avatar
...Roger...
I lower the column,then the left dash and then pull the switch out.
Old Mar 28, 2010 | 09:19 PM
13rooster's Avatar
13rooster
I have to replace mine also on a 78 but I am sure it is a little different. How did yours react as far as going out. On mine all my lights come on except the headlights, is that what yours has done.
Old Mar 28, 2010 | 10:17 PM
...Roger...
Do you have power to the headlight portion of the headlight switch ?
Old Mar 28, 2010 | 10:21 PM
13rooster's Avatar
13rooster
I do not know what color wire is the lead for the headlights and there is no fuse for just the headlights. The last night I drove it with headlights on I could smell wires getting hot. There is suppose to be a relay in the switch so I am hoping just a new switch will fix it.
Old Mar 28, 2010 | 10:42 PM
...Roger...
The heavy 12 red at the switch is for the headlights. I don't have a 78 diagram handy but some cars have a fusible link dedicated to the headlights. Check the 12 red for power before replacing the switch.
Old Mar 28, 2010 | 10:53 PM
Tom73's Avatar
Tom73
...and there is no fuse for just the headlights.
The fuse is part of the dimmer switch on the floorboard.
Old Mar 28, 2010 | 11:05 PM
...Roger...
A fuse inside the dimmer switch ?
Old Mar 28, 2010 | 11:11 PM
13rooster's Avatar
13rooster
I am sure the dimmer switch is in the column.
Old Mar 28, 2010 | 11:12 PM
13rooster's Avatar
13rooster
Thanks Roger. Will look at it tomorrow.
Old Mar 28, 2010 | 11:19 PM
...Roger...
Your welcome. I found my diagram of the 78 and it does have a separate fusible link down at the starter for the headlights.
Old Mar 29, 2010 | 01:13 AM
chvet73's Avatar
chvet73
Stock '73 dimmer is on the floor. Drop the steering column and take the left dash panel out far enough to change the switch. Not one of the most fun things I've done to my car.
Old Mar 30, 2010 | 11:20 AM
kapla74's Avatar
kapla74
problem is putting everything back together,,,those threads like to disapear and the bolts turn loose....I need to replace mine soon,,,my plunger if not pulled carefully like to go all the way out and finish out of the swicht...i use the low e-actuator to lift the lights...
Old Mar 30, 2010 | 11:25 AM
MrJlr's Avatar
MrJlr
I did my '74 about a year ago...almost as much fun as a heater core....
To 73 headlight switch
